去倒垃圾时,捡到一个别人扔掉的移动浪潮ipbs8400盒子(本人座标云南,盒子是不是云南移动的就不知道了)。回家上电试试,电源灯亮,接电视机和显示器没反应,没输出信号,usb和网线无反应。看封贴纸是已经拆机过,可能刷过机。拆开看一下,没看出来明显问题,焊上ttl针,ch340接上试一下,能跑码,能输入命令,但报错,晨星MSO9280芯片,1+8G,1080,里面好像是中兴的系统,不知是不是原始的,也无法备份。网上找了几个MstarUpgrade.bin,试刷后,只有中兴的系统有所反应,但都报错[ERROR] Secure_doAuthentication:94: Error: Authentication Fail!!验证失败。在此请教一下,所报错误是什么问题?刷机包的内容是否刷进去了?
下面报错的部分标识红色 Xshell 7 (Build 0090) Copyright (c) 2020 NetSarang Computer, Inc. All rights reserved.
Type `help' to learn how to use Xshell prompt. [D:\~]$
Connecting to COM3... Connected.
AC_ON MIU0_DQS-OK BIST0- MIU0-1024_U Start uboot
Relocation Offset is: 011d7000 [AT][MB][start ub][344]
U-Boot 2011.06-00075-gf0d5ade-dirty (Dec 05 2016 - 17:39:37)
[MIU INFO] miu opencreate instance at 559e9418 with private size 80 bytes at 559e9460 create instance at 559e94b8 with private size 52 bytes at 559e9500
uboot held at [557ddf60~56b00000],size=013220a0 CPU : Clippers Board: BD_MST207C_D01A_S_CLIPPERS DRAM: 875 MiB Now running in RAM - U-Boot at: 55c00000
eMMC: HS200 200MHz eMMC 7.28 GB [E8FFF8h] In: serial Out: serial Err: serial Net: zte_shutdow =false No ethernet found. MAC: 0xf2: 0x24: 0xf0: 0xfd:0x77: 0x6 msIR_Initialize
[CPU INFO] cpu opencreate instance at 559f99c0 with private size 44 bytes at 559f9a08 CPUIoctl - MDrv_CMD_CPU_QueryClock [UTOPIA INFO] close moduleNames[38]: MODULE_CPU
[AT][MBoot][Driver Init][494]
Starting logo [ERROR] Secure_doAuthentication:94: Error: Authentication Fail!! jump_to_console start!! << MStar >># mmcinfo Device: Mstar-eMMC Manufacturer ID: 15 OEM: 0 Name: 8WPD3 Tran Speed: 25000000 Rd Block Len: 512 MMC version 4.0 High Capacity: Yes Capacity: 7.3 GiB Bus Width: 8-bit << MStar >># cust Check USB port[0]: Host type:2 scanning bus for devices... [USB] interface[0] conf:1 value ff: 1 USB Device(s) found scanning bus for storage devices... 0 Storage Device(s) found Check USB port[1]: Host type:2 scanning bus for devices... [USB] interface[0] conf:1 value 8: 1 USB Device(s) found scanning bus for storage devices... bulk max packet size: ep 200 ep2 200 max lun:0 1 Storage Device(s) found ** Partition 0 not valid on device 0 **
** Unable to use usb 0:0 for fatload ** reading /MstarUpgrade.bin
1 bytes read ** Partition 0 not valid on device 0 **
** Unable to use usb 0:0 for fatload ** reading /SbootUpgrade.bin
** Unable to read "/SbootUpgrade.bin" from usb 0:1 ** ** Partition 2 not valid on device 0 **
** Unable to use usb 0:2 for fatload ** ** Partition 3 not valid on device 0 **
** Unable to use usb 0:3 for fatload ** ** Partition 4 not valid on device 0 **
** Unable to use usb 0:4 for fatload ** ** Partition 0 not valid on device 0 **
** Unable to use usb 0:0 for fatload ** reading /MbootUpgrade.bin
** Unable to read "/MbootUpgrade.bin" from usb 0:1 ** ** Partition 2 not valid on device 0 **
** Unable to use usb 0:0 for fatload ** reading /UrsaUpgrade.bin
** Unable to read "/UrsaUpgrade.bin" from usb 0:1 ** ** Partition 2 not valid on device 0 **
** Unable to use usb 0:4 for fatload ** Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Current state ->[0x8] [ERROR] count_data_crc32_getenv:799: checksum :0Xeacf7967 ; savesum :0X59e440c9 [ERROR] count_data_crc32_getenv:800: ## CRC check Error, panel_crc Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done [ERROR] panel_dinit:592: panel_dinit: Read_PanelParaFromflash() failed, at 592 Error : panel_init fail!! ** Partition 0 not valid on device 0 **
1 bytes read reading /MstarUpgrade.bin
16384 bytes read reading /MstarUpgrade.bin
469213216 bytes read ** Bad Signature on 0:15: expected 0x5840, got 0x0000 Error >> end searching partition storage is empty Saving Environment to MMC... Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done
>> mmc erase.p MBOOT MMC erase: dev # 0, user area part, block # 4096, count 6144 (unit: sector)... 6144 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 4000 1C4860
>> mmc write.p 20200000 MBOOT 1C4860 1 secure_image_check 20200000 1C4860 MBOOT mmc read.p 0x203c4860 MBOOT 0x20 3621 blocks written: OK
>> mmc erase.p MPOOL MMC erase: dev # 0, user area part, block # 10240, count 4096 (unit: sector)... 4096 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 1C9000 200000
>> mmc write.p 20200000 MPOOL 200000 1 4096 blocks written: OK
>> mmc erase.p misc MMC erase: dev # 0, user area part, block # 14336, count 8192 (unit: sector)... 8192 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 3CA000 400000
>> mmc write.p 20200000 misc 400000 1 8192 blocks written: OK
>> mmc erase.p logo MMC erase: dev # 0, user area part, block # 30720, count 32768 (unit: sector)... 32768 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 7CB000 1000000
>> mmc write.p 20200000 logo 1000000 1 32768 blocks written: OK
>> mmc erase.p recovery MMC erase: dev # 0, user area part, block # 63488, count 40960 (unit: sector)... 40960 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 17CC000 1400000
>> mmc write.p 20200000 recovery 1400000 1 secure_image_check 20200000 1400000 recovery [ERROR] _RawData_Authentication:1503: ###1 [ERROR] _RawData_Authentication:1505: ###2 40960 blocks written: OK
>> mmc erase.p boot MMC erase: dev # 0, user area part, block # 104448, count 32768 (unit: sector)... 32768 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 2BCD000 1000000
>> mmc write.p 20200000 boot 1000000 1 secure_image_check 20200000 1000000 boot [ERROR] _RawData_Authentication:1503: ###1 [ERROR] _RawData_Authentication:1505: ###2 32768 blocks written: OK
>> mmc erase.p cache MMC erase: dev # 0, user area part, block # 137216, count 1572864 (unit: sector)... 1572864 blocks erase: OK
>> mmc erase.p tvconfig MMC erase: dev # 0, user area part, block # 1710080, count 20480 (unit: sector)... 20480 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 3BCE000 A00000
>> mmc write.p 20200000 tvconfig A00000 1 Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done 20480 blocks written: OK
>> mmc erase.p tvservice MMC erase: dev # 0, user area part, block # 1730560, count 122880 (unit: sector)... 122880 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 45CF000 3C00000
>> mmc write.p 20200000 tvservice 3C00000 1 122880 blocks written: OK
>> mmc erase.p tvdatabase MMC erase: dev # 0, user area part, block # 1853440, count 16384 (unit: sector)... 16384 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 81D0000 800000
>> mmc write.p 20200000 tvdatabase 800000 1 Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done 16384 blocks written: OK
>> mmc erase.p tvcustomer MMC erase: dev # 0, user area part, block # 1869824, count 32768 (unit: sector)... 32768 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 89D1000 476DF4
>> mmc write.p 20200000 tvcustomer 476DF4 1 9143 blocks written: OK
>> mmc erase.p system MMC erase: dev # 0, user area part, block # 1902592, count 1572864 (unit: sector)... 1572864 blocks erase: OK
>> filepartload 20200000 MstarUpgrade.bin 8E48000 65FD1BD
>> mmc unlzo 20200000 65FD1BD system 1 Uncompressing ... Continue uncompressing and writing emmc... Depressed OK! Write to system partition OK! Total write size: 0x9600000
>> filepartload 20200000 MstarUpgrade.bin F446000 5F8C869
>> mmc unlzo.cont 20200000 5F8C869 system 1 Uncompressing ... Continue uncompressing and writing emmc... Depressed OK! Write to system partition OK! Total write size: 0x9600000
>> filepartload 20200000 MstarUpgrade.bin 153D3000 6A5DD3F
>> mmc unlzo.cont 20200000 6A5DD3F system 1 Uncompressing ... Continue uncompressing and writing emmc... Depressed OK! Write to system partition OK! Total write size: 0x9600000
>> filepartload 20200000 MstarUpgrade.bin 1BE31000 9A33E
>> mmc unlzo.cont 20200000 9A33E system 1 Uncompressing ... Continue uncompressing and writing emmc... Depressed OK! Write to system partition OK! Total write size: 0x9600000
>> filepartload 20200000 MstarUpgrade.bin 1BECC000 9A2DB
>> mmc unlzo.cont 20200000 9A2DB system 1 Uncompressing ... Continue uncompressing and writing emmc... Depressed OK! Write to system partition OK! Total write size: 0x9600000
>> filepartload 20200000 MstarUpgrade.bin 1BF67000 12819
>> mmc unlzo.cont 20200000 12819 system 1 Uncompressing ... Continue uncompressing and writing emmc... Depressed OK! Write to system partition OK! Total write size: 0x1200000
>> mmc erase.p userdata MMC erase: dev # 0, user area part, block # 3475456, count 11534336 (unit: sector)... 11534336 blocks erase: OK
>> setenv bootcmd mmc read.p 0x25000000 boot 0x00500000\; bootm 0x25000000
>> setenv recoverycmd mmc read.p 0x25000000 recovery 0x00B00000\; bootm 0x25000000
>> setenv ROOT root=/dev/ram rw rootwait
>> setenv CMA_REG CMA0=vdec,miu=0,hid=19,sz=0xA000000
>> setenv bootargs console=ttyS0,115200 androidboot.console=ttyS0 androidboot.hardware=clippers $(ROOT) init=/init CORE_DUMP_PATH=/data/core_dump.%e.%%p.gz KDebug=1 delaylogo=true $(CMA_REG) ENV=EMMC
>> setenv kernelProtectBist block
>> setenv sync_miuprot 1
>> setenv bootdelay true
>> setenv bootlogo_buffer E_MMAP_ID_MFE
>> setenv bootlogo_gopidx 3
>> setenv db_table 0
>> setenv verify n
>> setenv thirdpartydtv 0
>> setenv debuglevel 2
>> setenv mdebug false
>> setenv music 0
>> setenv mboot_default_env 0
>> setenv sync_mmap 1
>> setenv Watchdog_enable FALSE
>> saveenv Saving Environment to MMC... Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done
>> printenv CMA_REG=CMA0=vdec,miu=0,hid=19,sz=0xA000000 CMA_REG0=CMA1=mali0,miu=0,hid=16,sz=0x1000000 CMA_REG1=CMA1=mali,miu=0,hid=16,sz=0x2000000 COMControlFlag=0 E_DFB_FRAMEBUFFER_ADR=0x396E0000 E_DFB_FRAMEBUFFER_LEN=0x1200000 E_EMAC_MEM_ADR=0x31600000 E_EMAC_MEM_LEN=0x100000 E_LX_MEM_ADR=0x200000 E_LX_MEM_LEN=0x31400000 E_MMAP_ID_CAMERA_ADR=0x3F706000 E_MMAP_ID_CAMERA_LEN=0x600000 E_MMAP_ID_GOP_FB_ADR=0x3A8E0000 E_MMAP_ID_GOP_FB_LEN=0x1900000 E_MMAP_ID_HW_AES_BUF_ADR=0x3D1E0000 E_MMAP_ID_HW_AES_BUF_LEN=0xC0000 E_MMAP_ID_JPD_READ_ADR=0x380AD000 E_MMAP_ID_JPD_READ_LEN=0x600000 E_MMAP_ID_JPD_WRITE_ADR=0x386AD000 E_MMAP_ID_JPD_WRITE_LEN=0x3FC000 E_MMAP_ID_MAD_DEC_ADR=0x37BB0000 E_MMAP_ID_MAD_DEC_LEN=0x0 E_MMAP_ID_MAD_R2_ADR=0x37130000 E_MMAP_ID_MAD_R2_LEN=0x800000 E_MMAP_ID_MAD_SE_ADR=0x37930000 E_MMAP_ID_MAD_SE_LEN=0x280000 E_MMAP_ID_MBOOT_LOAD_ADR=0x33B00000 E_MMAP_ID_MBOOT_LOAD_LEN=0xA00000 E_MMAP_ID_MBOOT_MB_ADR=0x34500000 E_MMAP_ID_MBOOT_MB_LEN=0xF00000 E_MMAP_ID_MBOOT_MEM_USAGE_ADR=0x33B00000 E_MMAP_ID_MBOOT_MEM_USAGE_LEN=0x2500000 E_MMAP_ID_MBOOT_USB_ADR=0x35400000 E_MMAP_ID_MBOOT_USB_LEN=0x800000 E_MMAP_ID_MFE_ADR=0x390E0000 E_MMAP_ID_MFE_LEN=0x600000 E_MMAP_ID_NUTTX_MEM_ADR=0x3C1E0000 E_MMAP_ID_NUTTX_MEM_LEN=0x1000000 E_MMAP_ID_PHOTO_INTER_ADR=0x38AA9000 E_MMAP_ID_PHOTO_INTER_LEN=0x630000 E_MMAP_ID_PM51_USAGE_MEM_ADR=0x0 E_MMAP_ID_PM51_USAGE_MEM_LEN=0x10000 E_MMAP_ID_VDEC_CPU_ADR=0x3D4A0000 E_MMAP_ID_VDEC_CPU_LEN=0x300000 E_MMAP_ID_VE_ADR=0x3EFA0000 E_MMAP_ID_VE_LEN=0x201000 E_MMAP_ID_XC_MAIN_FB_ADR=0x33B00000 E_MMAP_ID_XC_MAIN_FB_LEN=0x2000000 KERNEL_PROTECT=DRAM_SIZE1=0x40000000 DRAM_SIZE2=0x0 MIU0_GROUP_PRIORITY=1:0:2:3 MIU0_GROUP_SELMIU=0000:0000:0000:0000 MIU1_GROUP_PRIORITY=1:0:2:3 MIU1_GROUP_SELMIU=2E82:0021:1FA1:01C0 MMC_CAPACITY_512=15269880 MstarUpgrade_complete=1 ROOT=root=/dev/ram rw rootwait UARTOnOff=on UpgradeImage=MstarUpgrade.bin Watchdog_enable=FALSE bPolPWM=0x0 baudrate=115200 board_crc=5B44586E boardtype=0 boot1_ver=V0020 boot_from_recovery=3 boot_revision=V0036 bootargs=console=ttyS0,115200 androidboot.console=ttyS0 androidboot.hardware=clippers root=/dev/ram rw rootwait init=/init CORE_DUMP_PATH=/data/core_dump.%e.%%p.gz KDebug=1 delaylogo=true CMA0=vdec,miu=0,hid=19,sz=0xA000000 ENV=EMMC bootcmd=mmc read.p 0x25000000 boot 0x00500000; bootm 0x25000000 bootcount=0 bootdelay=true bootdlevel=2 bootlogo_buffer=E_MMAP_ID_MFE bootlogo_gopidx=3 bootscript=echo Running bootscript from mmc${mmcdev} ...; source ${loadaddr} chipid=101400010000ce747f7505e0 close_log=yes console=ttyS2,115200n8 db_crc=8B4CC00 db_table=0 dbglevel=quiet debuglevel=2 delaylogo_miuID=0 deviceid=NULL filesize=1BF79819 force_upgrade=0x08 hdmi_hdcp_mode=0 info_exchange=emmc kernelProtectBist=block keybank_done=1 loadaddr=0x82000000 loadbootscript=fatload mmc ${mmcdev} ${loadaddr} boot.scr loaduimage=fatload mmc ${mmcdev} ${loadaddr} uImage logo_crc=A3E51B43 macaddr=F2:24:F0:FD:77:06 mboot_default_env=0 mdebug=false mlevel=1 mmcargs=setenv bootargs console=${console} vram=${vram} root=${mmcroot} rootfstype=${mmcrootfstype} mmcboot=echo Booting from mmc${mmcdev} ...; run mmcargs; bootm ${loadaddr} mmcdev=0 mmcrelwr=2 mmcroot=/dev/mmcblk0p2 rw mmcrootfstype=ext3 rootwait mmcslcmode=0 music=0 music_crc=506D871E music_vol=0x2E panel_crc=59E440C9 panel_name=DACOUT_576P_50 panel_path=/config/panel/DACOUT_576P_50.ini partno=1 pnl_pwmch=2 recoverycmd=mmc read.p 0x25000000 recovery 0x00B00000; bootm 0x25000000 reproducerate1080=0 reproducerate480=0 reproducerate576=168365065 reproducerate720=0 resolution=1 resolution_reset=1 runlevel=0 secure_result=0 serialno=null serianum=null stderr=serial stdin=serial stdout=serial swing_level=250 sync_miuprot=1 sync_mmap=1 system=safe thirdpartydtv=0 u16DivPWM=0x0 u16MaxPWMvalue=0x0 u16MinPWMvalue=0x0 u16PanelDCLK=27 u32PWMDuty=0x0 u32PWMPeriod=0x0 ubispeedup=UBI uimode=720p upgrade_factorydb=TRUE upgrade_mode=null usbtty=cdc_acm verify=n videotype=3 vram=16M zte.soft.shutdown=false
Environment size: 4258/65532 bytes AP upgrade OK!~ All Upgrade File Had Finished !! Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done
[AT][MB][start do_reset] do_reset: Using RIU_MAP: 0x1f000000, at 55
Relocation Offset is: 011d7000 [AT][MB][start ub][361]
eMMC: HS200 200MHz eMMC 7.28 GB [E8FFF8h] In: serial Out: serial Err: serial Net: zte_shutdow =false No ethernet found. MAC: 0xf2: 0x24: 0xf0: 0xfd:0x77: 0x6 mmc change mount : tvconfig Size of file "/config/sys.ini" from mmc device 0 partition tvconfig: 986 bytes Loading file "/config/sys.ini" at offset 0x0 from mmc device 0 partition tvconfig 986 bytes read sizeof( sys ini script ) --------> 986 bytes Half model.ini path --> /config/model/Customer_1.ini Full model.ini path --> /config/model/Customer_1.ini Full Customer.ini for keypad path --> /config/model/Customer_1.ini Size of file "/config/model/Customer_1.ini" from mmc device 0 partition tvconfig: 7504 bytes Loading file "/config/model/Customer_1.ini" at offset 0x0 from mmc device 0 partition tvconfig 7504 bytes read sizeof( model ini script ) --------> 7504 bytes Half panel.ini path --> /config/panel/DACOUT_1080P_50.ini Full panel.ini path --> /config/panel/DACOUT_1080P_50.ini Half board.ini path --> /config/board.ini Full board.ini path --> /config/board.ini mmc change mount : tvconfig Size of file "/boot.ini" from mmc device 0 partition tvconfig: 232 bytes Loading file "/boot.ini" at offset 0x0 from mmc device 0 partition tvconfig 232 bytes read sizeof( boot ini script ) --------> 232 bytes gMusicPath --> /boot0.mp3 gLogoPath --> /boot0.jpg music_vol -> [0x2E] mmc change mount : tvconfig Size of file "/boot0.jpg" from mmc device 0 partition tvconfig: 51139 bytes Size of file "/boot0.mp3" from mmc device 0 partition tvconfig: 59952 bytes mmc change mount : tvconfig Size of file "/boot0.jpg" from mmc device 0 partition tvconfig: 51139 bytes Loading file "/boot0.jpg" at offset 0x0 from mmc device 0 partition tvconfig 51139 bytes read mmc change mount : tvconfig Size of file "/boot0.mp3" from mmc device 0 partition tvconfig: 59952 bytes Loading file "/boot0.mp3" at offset 0x0 from mmc device 0 partition tvconfig 59952 bytes read music_offset = 0xc803 music_size = 0xea30 mmc change mount : tvconfig Size of file "/config/panel/DACOUT_576P_50.ini" from mmc device 0 partition tvconfig: 5988 bytes Loading file "/config/panel/DACOUT_576P_50.ini" at offset 0x0 from mmc device 0 partition tvconfig 5988 bytes read sizeof( panel ini script ) --------> 5988 bytes u32PeriodPWM = 0 u32DutyPWM = 0x0 mmc change mount : tvconfig Size of file "/config/board.ini" from mmc device 0 partition tvconfig: 472 bytes Loading file "/config/board.ini" at offset 0x0 from mmc device 0 partition tvconfig 472 bytes read sizeof( board ini script ) --------> 472 bytes mmc change mount : tvconfig Size of file "/config/dfbrc.ini" from mmc device 0 partition tvconfig: 1364 bytes Loading file "/config/dfbrc.ini" at offset 0x0 from mmc device 0 partition tvconfig 1364 bytes read sizeof( dfb ini script ) --------> 1364 bytes 218 blocks written: OK Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done msIR_Initialize
[AT][MBoot][Driver Init][1213]
Starting logo mmc change mount : tvconfig Size of file "/config/mmap.ini" from mmc device 0 partition tvconfig: 50387 bytes Loading file "/config/mmap.ini" at offset 0x0 from mmc device 0 partition tvconfig 50387 bytes read no miu_setting information in mmap.ini no miu_setting information in mmap.ini No LX_MEM2 information No LX_MEM3 information Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done to setenv MMC_CPCT_NAME Saving Environment to MMC... Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done Saving Environment to MMC... Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done
Relocation Offset is: 011d7000 [AT][MB][start ub][374]
[AT][MBoot][Driver Init][524]
Starting logo Customer key bank is not encrypted Saving Environment to MMC... Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done 3 blocks written: OK 3 blocks written: OK Saving Environment to MMC... Writing to MMC(0)... 128 blocks written: OK 128 blocks written: OK done
Relocation Offset is: 011d7000 [AT][MB][start ub][350]
[AT][MBoot][Driver Init][500]
