型号:威刚SP900 128GB 4贴tsop芯片. 主控:SF2241VB4; 颗粒无法确认,丝印是60076312 5301410664新手没转接卡是直接接的sata.
请大佬帮忙分析一下,Flash Test 连续的报错,是什么问题,谢谢.
[Thu 10/13/2022 13:05:36] - Instructing the operating system to purge any existing cached data for device: '1:0:0:0'[Thu 10/13/2022 13:05:41] - Issuing a discovery command for device: '1:0:0:0'
[Thu 10/13/2022 13:05:47] - Discovery command completed...
[Thu 10/13/2022 13:05:47] - Waiting 5 seconds for the system to settle...
[Thu 10/13/2022 13:05:52] - Device designation string '1:0:0:0' is mapped to node '/dev/sg1'
[Thu 10/13/2022 13:05:52] - Proceeding to process SSD device with the following parameters:
DeviceName = /dev/sg1
MFP Package Filename = /root/2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
Configuration File = /root/2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/28687.12345.687.driveconfig
Serial No. = 124125
World Wide Name = 12312412
[Thu 10/13/2022 13:05:52] - Successfully received the IDENTIFY data from the drive...
[Thu 10/13/2022 13:05:52] - Validating Manufacturing Firmware Package: /root/2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Thu 10/13/2022 13:05:52] - Successfully opened the package: /root/2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Thu 10/13/2022 13:05:52] - file /root/2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/28687.12345.687.driveconfig Loaded successfully
[Thu 10/13/2022 13:05:52] - Warning: Unable to query diagnostics information to perform power management settings check
[Thu 10/13/2022 13:05:52] - B01 Power Management configuration request detected
[Thu 10/13/2022 13:05:52] - Successfully extracted *.DriveConfig file: /root/2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/28687.12345.687.driveconfig
[Thu 10/13/2022 13:05:52] - Extracted Config_ID: 1 (28687) in DriveConfig file: /root/2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/28687.12345.687.driveconfig
[Thu 10/13/2022 13:05:52] - Extracted SerialOutputControl: 0
[Thu 10/13/2022 13:05:52] - Searching for flashware image for configuration 28687
[Thu 10/13/2022 13:05:52] - Manifest found for configuration 28687
[Thu 10/13/2022 13:05:52] - Flashware image extracted: 28687_fw_cl_mlc_Toshiba_64Gb_TH58TEG8DDKTA20_1Q_2C_2D_PP_R03019_s512.vic
[Thu 10/13/2022 13:05:52] - Searching for manufacturing image for configuration 28687
[Thu 10/13/2022 13:05:52] - Manufacturing image extracted: 28687_mf_mlc_Toshiba_64Gb_TH58TEG8DDKTA20_1Q_2C_2D_PP_R03019_s512.vic
[Thu 10/13/2022 13:05:52] - Proceeding in ROM mode, download feature 3...
[Thu 10/13/2022 13:05:52] - Successfully downloaded MFB to the drive...
[Thu 10/13/2022 13:05:52] - Waiting (5 sec) for the drive to settle...
[Thu 10/13/2022 13:05:57] - Successfully received the IDENTIFY data from the drive...
[Thu 10/13/2022 13:05:57] - Firmware revision reported to be: '60AABBM0'. This indicates MFB download was successful.
[Thu 10/13/2022 13:05:57] - Successfully enabled SMART capabilities...
[Thu 10/13/2022 13:05:59] - Successfully issued a diagnostic unlock...
[Thu 10/13/2022 13:06:00] - Performing the flash test of block 0 (0x0000)...
[Thu 10/13/2022 13:06:02] - Flash Test Results:
Flash Test Parameters:
Block Count: 0
Page Count: 1
Bus Count: 1
Chip Enabled Count: 2
Die Count: 2
Lane Count: 4
Plane Count: 2
Results Notes:
N1 - At least one page tested and passed with no bit errors.
N2 - No test data available. Test may have aborted, or failed during the testing.
N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
N4 - At least one erased page tested had bit error rate greater than half the correction power.
N5 - Walking zeros test failed.
N6 - Walking ones test failed.
N7 - Block contained factory bad block markings and testing was skipped.
N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
N9 - Block in plane 0 was marked as a factory bad block.
N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
N11 - Block in plane 1 was marked as a factory bad block.
| Bus | CE | Die | Lane | Value | Result Notes | Overall |
| 0 | 0 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 0 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 0 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 0 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 0 | 1 | 3 | 0x0001 | N1 | PASS |
| 0 | 1 | 0 | 0 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 1 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 2 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 0 | 3 | 0x0374 | N4,N5,N6,N8,N10 | FAIL |
| 0 | 1 | 1 | 0 | 0x0001 | N1 | PASS |
| 0 | 1 | 1 | 1 | 0x0001 | N1 | PASS |
| 0 | 1 | 1 | 2 | 0x0001 | N1 | PASS |
| 0 | 1 | 1 | 3 | 0x0001 | N1 | PASS |
Total Number of test results: 16
Number of failures: 8
Number of Passed with warnings: 0
No. Passed without warnings: 8
[Thu 10/13/2022 13:06:02] - End of Genesis manufacturing log.
[Thu 10/13/2022 13:06:02] - Exiting...
补充内容 (2022-11-1 11:08):
后续来了,,拆颗粒,上usb主控板,读取的ID是:45 3A 94 93 76 51 是sandisk标的mlc颗粒.SF2241vb4好像这个颗粒没有对应的配置文件吧.改几个u盘算了. |
