AIMP v5.11.2421 (30.01.2023)Audio converter: support for QAAC64 command line encoder
Player: internet-radio - support for JSON-based metadata
Player: internet radio - support for streams with 24 bit per sample or above
Playlist: support for "comment" tag field
Music library: an ability to group items in table by parent folder (use filename column for that)
General: the WavPack codec has been updated to v5.6
General: support for surrogate characters in utf8-stream
Skin engine: memory consumption that required for text rendering reduced at 33%
Fixed: player - chapters in QuickTime format (MP4) cannot be read by 64-bit app version
Fixed: player - the "previous/next track" commands will be ignored if it called while next track is pre-loading
Fixed: playlist - Linux - items reordering via drag-n-drop does not work
Fixed: music library - find missplaced files - search button is inactive until you select at least one entry
Fixed: music library - an error occurs on attempt to start bookmark playback if bookmark source and playing playlists are unavailable
Fixed: scheduler - the "suspend playback on end of file" command conflicts with the "add pause between tracks" option
Fixed: plugins - scrobbler - artist field has no link
