楼主 |
发表于 2023-8-4 18:37:52
显示全部楼层
- SDK 5.0.S.0
- [ 0.000000] Linux version 3.10.108 (qingchu.zeng@Sw-com) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r202) ) #4 SMP Wed Nov 30 18:51:18 CST 2022
- [ 0.000000]
- [ 0.000000] The CPU feqenuce set to 880 MHz
- [ 0.000000] GCMP present
- [ 0.000000] CPU0 revision is: 0001992f (MIPS 1004Kc)
- [ 0.000000] Software DMA cache coherency
- [ 0.000000] Determined physical RAM map:
- [ 0.000000] memory: 10000000 [url=home.php?mod=space&uid=3057940]@[/url] 00000000 (usable)
- [ 0.000000] Initrd not found or empty - disabling initrd
- [ 0.000000] Zone ranges:
- [ 0.000000] DMA [mem 0x00000000-0x00ffffff]
- [ 0.000000] Normal [mem 0x01000000-0x0fffffff]
- [ 0.000000] Movable zone start for each node
- [ 0.000000] Early memory node ranges
- [ 0.000000] node 0: [mem 0x00000000-0x0fffffff]
- [ 0.000000] Detected 3 available secondary CPU(s)
- [ 0.000000] Primary instruction cache 32kB, 4-way, VIPT, linesize 32 bytes.
- [ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
- [ 0.000000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
- [ 0.000000] PERCPU: Embedded 7 pages/cpu @81a35000 s6016 r8192 d14464 u32768
- [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
- [ 0.000000] Kernel command line: console=ttyS1,57600n8 root=/dev/mtdblock5 rootfstype=squashfs,jffs2
- [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
- [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
- [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
- [ 0.000000] Writing ErrCtl register=00009200
- [ 0.000000] Readback ErrCtl register=00009200
- [ 0.000000] Memory: 251372k/262144k available (5980k kernel code, 10772k reserved, 1994k data, 276k init, 0k highmem)
- [ 0.000000] Hierarchical RCU implementation.
- [ 0.000000] NR_IRQS:128
- [ 0.000000] console [ttyS1] enabled
- [ 0.120000] Calibrating delay loop... 577.53 BogoMIPS (lpj=1155072)
- [ 0.160000] pid_max: default: 32768 minimum: 301
- [ 0.164000] Mount-cache hash table entries: 512
- [ 0.168000] launch: starting cpu1
- [ 0.172000] launch: cpu1 gone!
- [ 0.172000] Primary instruction cache 32kB, 4-way, VIPT, linesize 32 bytes.
- [ 0.172000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
- [ 0.172000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
- [ 0.172000] CPU1 revision is: 0001992f (MIPS 1004Kc)
- [ 0.204000] Synchronize counters for CPU 1: done.
- [ 0.208000] launch: starting cpu2
- [ 0.212000] launch: cpu2 gone!
- [ 0.212000] Primary instruction cache 32kB, 4-way, VIPT, linesize 32 bytes.
- [ 0.212000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
- [ 0.212000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
- [ 0.212000] CPU2 revision is: 0001992f (MIPS 1004Kc)
- [ 0.244000] Synchronize counters for CPU 2: done.
- [ 0.248000] launch: starting cpu3
- [ 0.252000] launch: cpu3 gone!
- [ 0.252000] Primary instruction cache 32kB, 4-way, VIPT, linesize 32 bytes.
- [ 0.252000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
- [ 0.252000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
- [ 0.252000] CPU3 revision is: 0001992f (MIPS 1004Kc)
- [ 0.280000] Synchronize counters for CPU 3: done.
- [ 0.284000] Brought up 4 CPUs
- [ 0.288000] NET: Registered protocol family 16
- [ 0.588000] release PCIe RST: RALINK_RSTCTRL = 7000000
- [ 0.592000] PCIE PHY initialize
- [ 0.596000] ***** Xtal 40MHz *****
- [ 0.600000] start MT7621 PCIe register access
复制代码
