查看: 481|回复: 6
[C51] 求修改24c02里记录的数据
发表于 2024-4-29 11:23:59 | 显示全部楼层 |阅读模式
这是数据的解释(=号后面的内容存储在24c02内),那位老师可以修改请私信我谈价格。
  1. board_info_version = 4
  2. algorithm_and_key_version = 0x11
  3. board_sn = FXDZYN3BAJHBA06FN
  4. chip_die = ED
  5. chip_marking = J1CT21BK20
  6. chip_bin = 3
  7. ft_version = F1V04B2C2
  8. pcb_version = 0x130
  9. bom_version = 0x10
  10. sensor_type = 0x0
  11. sensor_addr[0] = 0x0
  12. sensor_addr[1] = 0x0
  13. sensor_addr[2] = 0x0
  14. sensor_addr[3] = 0x0
  15. sensor_type = 0x8b
  16. sensor_addr = 0xf
  17. chip_tech = AA
  18. board_name =
  19. factory_job = FXDZ20210805003-ZB
  20. board_info_crc = 0x1
  21. voltage = 1380
  22. frequency = 545
  23. nonce_rate = 9997
  24. pcb_temp_in = 33
  25. pcb_temp_out = 35
  26. test_version = 1
  27. test_standard = 0
  28. param_info_crc = 0x15
  29. pt1_result = 1
  30. pt1_count = 1
  31. pt2_result = 1
  32. pt2_count = 1
复制代码
下面是编程器读存储器的数据
  1. 0x0000 04 11 48 83 6E B9 FB 95   50 18 D7 B3 88 FD DF 5A
  2. 0x0010 12 7D 93 FE 4B 7D CB 8B   76 A5 55 2F 99 D3 26 DD
  3. 0x0020 63 8B BE ED FE 4E CD 06   F7 3B F1 86 91 3B F6 73
  4. 0x0030 B2 EE 73 D3 E9 9D 07 AC   8A 04 5A 93 EB 3F 45 04
  5. 0x0040 AB BC 23 8C C3 86 8B A6   E3 FA 20 17 25 9D 0C DE
  6. 0x0050 1F 69 5F 34 04 99 F0 B0   38 2C 17 35 8B EE B6 82
  7. 0x0060 93 E4 55 F8 CC BA 3D 7D   E5 F4 11 EC 96 9C 8E 00
  8. 0x0070 8C 05 FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
  9. 0x0080 FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
  10. 0x0090 FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
  11. 0x00A0 FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
  12. 0x00B0 FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
  13. 0x00C0 FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
  14. 0x00D0 FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
  15. 0x00E0 FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF FF
  16. 0x00F0 FF FF FF FF FF FF FF FF   FF FF FF FF FF FF FF 5A
复制代码
发表于 2024-4-29 18:20:30 | 显示全部楼层
renpeng009 发表于 2024-4-29 17:57
我擦。。。。。。。。。。这不是直接改就行了?
有校验,如果不知道校验算法,改不对就废了。
发表于 2024-5-1 07:28:29 来自手机浏览器 | 显示全部楼层
多读几组数据看看
发表于 2024-5-1 15:00:31 | 显示全部楼层
似乎对应不上啊
 楼主| 发表于 2024-5-1 21:28:53 | 显示全部楼层
sunbester 发表于 2024-5-1 07:28
多读几组数据看看
已经找到,电压和频率存储的地址,频率545,电压1380和1360,不知道为什么频率或者电压有改变这段的数据都会变化
 楼主| 发表于 2024-5-1 21:29:24 | 显示全部楼层
 楼主| 发表于 2024-5-1 21:30:03 | 显示全部楼层
zchong 发表于 2024-5-1 15:00
似乎对应不上啊
GMT+8, 2025-9-17 03:15 , Processed in 0.109200 second(s), 8 queries , Gzip On, Redis On.
