查看: 720|回复: 4
[ASolid] AS2258量产一直报0x306错误
发表于 2025-11-29 16:28:18 | 显示全部楼层 |阅读模式
Day: (2025\11\29) Time: (16:23:10)  SlotNo:1
MP ver:V0205    MPBinType:73.0    RDTBinType:73.0
Test Station:EraseMP  Check RDT Table:0
INI file:E:\量产工具\点序AS2258\AS2258MP_Tool_V0205\AS_SSD_MP_Tool_V0205\INI_files\ini_Intel(89)\Intel_L06BB0KB_89 b4 78 32 aa 01 00.INI
   Serial Number write to infoblock: 00000000000000000142
   Drive Letter are Not Locked.
      IC Ver: AS2258
[ Success ] Check ICVer. OK, Total take 0.066 sec.
   Get CE Map=0, AutoCapacity_DynamicCE_En=1
   Scan all ID :
   CE_00: 89 B4 78 32 AA 01 00 00
   CE_01: 89 B4 78 32 AA 01 00 00
   CE_02: 89 B4 78 32 AA 01 00 00
   CE_03: 89 B4 78 32 AA 01 00 00
   CE_04: 89 B4 78 32 AA 01 00 00
   CE_05: 00 00 00 00 00 00 00 00
   CE_06: 89 B4 78 32 AA 01 00 00
   CE_07: 00 00 00 00 00 00 00 00
   CE_08: 89 B4 78 32 AA 01 00 00
   CE_09: 89 B4 78 32 AA 01 00 00
   CE_10: 89 B4 78 32 AA 01 00 00
   CE_11: 89 B4 78 32 AA 01 00 00
   CE_12: 89 B4 78 32 AA 01 00 00
   CE_13: 00 00 00 00 00 00 00 00
   CE_14: 00 00 00 00 00 00 00 00
   CE_15: 00 00 00 00 00 00 00 00
   Copy Temperature log 64 bytes
   Read RDT Info from BBT
   Issue ReadRDTInfo Command Failed !!!
   Reset Temperature log 64 bytes
[ Success ] Verify param.ini with Device Info OK- Total take 1.391 sec.
   Original CE Map=0, UI CE Map=0, Compare=0
   Set CE Map=0
   Start Scan Bad Block Progress ...
   Set EarlyBad_Spec= 0 per CE
   Select AutoCapacity_MaxBadPercent_11CE
   Get 11CE 480 GB, Max Bad block number Percent= 7
   Die Per Flash= 1;
   Plane Number = 4;
   Max Block Per CE= 2192;
   Get Max Bad block number Percent= 7
   Get Max Bad block number per Plane= 38
   FlashNumber=11, MaxBad_perPlane/Die=38
   Get CE Map=0
   Find BBT parameter
   Read BBT checksum:5572
        CENo_0/Die_0-> Early Bad Count: Plane0=7, Plane1=4, Plane2=3, Plane3=3
        CENo_1/Die_0-> Early Bad Count: Plane0=7, Plane1=3, Plane2=2, Plane3=4
        CENo_2/Die_0-> Early Bad Count: Plane0=7, Plane1=3, Plane2=2, Plane3=3
        CENo_3/Die_0-> Early Bad Count: Plane0=7, Plane1=3, Plane2=2, Plane3=4
        CENo_4/Die_0-> Early Bad Count: Plane0=8, Plane1=3, Plane2=2, Plane3=4
        CENo_6/Die_0-> Early Bad Count: Plane0=6, Plane1=2, Plane2=2, Plane3=3
        CENo_8/Die_0-> Early Bad Count: Plane0=8, Plane1=4, Plane2=3, Plane3=4
        CENo_9/Die_0-> Early Bad Count: Plane0=7, Plane1=3, Plane2=2, Plane3=5
        CENo_10/Die_0-> Early Bad Count: Plane0=7, Plane1=4, Plane2=2, Plane3=4
        CENo_11/Die_0-> Early Bad Count: Plane0=7, Plane1=4, Plane2=2, Plane3=3
        CENo_12/Die_0-> Early Bad Count: Plane0=7, Plane1=5, Plane2=4, Plane3=11
[ Success ] Scan Bad Process OK- Total take 29.270 sec.
   InfoBlock Reset Temperature log 64 bytes
   MPver 00 02 05 00 05
   FLH_IF=5
   Flh_Clk=7
   Get AutoCap_DynamicCE_En=0
   Run Info CE map=0, CE map=0
   flash num=11, ssd size=937703088, m_PhysicalSize=540672
   Two Pass Program Type = 0
[ Success ] Modify InfoBlock OK.
   Do PreFormat:
      occur error when Erase CMD
   CE Index=0x50, Unit Index=0x0
[ Fail ]  Error Message : Issue PreFormat-WriteInfoBlock Command Failed , ErrorCondition= 0x40
             Error Code : 0x306
             AP Command : [a1]-[1e]-[2e]-[0]-[1]-[0]-[0]-[0]-[0]-[0]-[0]-[0]
             OS LastError : [ 0 ]
             ATA Reg:[0][0][40][50][0][0]
[ Error End ] Time: (16:24:13)
发表于 2025-11-30 00:19:21 | 显示全部楼层
发表于 2025-12-1 08:53:16 | 显示全部楼层
发表于 2025-12-1 09:29:41 | 显示全部楼层
发表于 2025-12-1 10:07:06 | 显示全部楼层
GMT+8, 2026-9-16 19:23 , Processed in 0.218401 second(s), 12 queries , Gzip On, Redis On.
