如题,最近收拾老物件,翻出来一个机械键盘,本来以为早就废了,结果插上电还能亮,就是接触不良。寻思着反正闲着也是闲着,直接拆开看看究竟怎么回事,顺便记录一下过程,给同样有这毛病的朋友做个参考。
外壳是卡扣设计的,没有螺丝,用撬片沿着缝隙慢慢走一圈就开了,卡扣有点紧但好在没断,整个过程大概花了七八分钟。拆的时候一定要慢,老塑料容易脆,掰断卡扣就不好装了。
拆开发现灰尘厚厚一层,风扇叶片上全是絮状物,散热片缝隙里也塞满了毛絮,散热肯定受影响,难怪会接触不良。先用毛刷和吹气球把灰清了一遍,光这一步就弄下来不少东西。
上电之后能听到轻微异响,同时伴随着接触不良,初步判断是电源部分或者机械结构的问题。断电之后用手晃了晃,内部没有松动,那就更倾向于电子元件老化导致的。
对比了正常工作的同款,怀疑是接触不良导致的,拆开一看果然八九不离十。同款机器上这个位置的元件选型更好一些,估计是后期版本改进过,说明厂家也知道这是个通病。
顺手把散热硅脂也换了,这玩意儿时间长了容易干,影响散热,换了之后温度明显低了不少。原来的硅脂已经硬得像块饼干,难怪会接触不良,散热不好元件寿命肯定受影响。
修完之后又观察了一天,没有再复发,基本可以判定修复成功。这种问题最怕的就是当时好了、过几天又犯,所以多观察一段时间还是有必要的,不能急着下结论。
折腾了一晚上,总算修好了,虽然不是什么值钱的玩意儿,但动手的乐趣就在这儿。从接触不良到满血复活,整个过程记录下来,也算给后来人留个参考。
求个精华,混点家元,顺便记录一下过程,后面有新的进展再更新。
51sole.com/b2b/sides359429556.html
51sole.com/b2b/sides359429644.html
51sole.com/b2b/sides359429718.html
51sole.com/b2b/sides359429768.html
51sole.com/b2b/sides305591042.html
51sole.com/b2b/sides359429910.html
51sole.com/b2b/sides359429981.html
51sole.com/b2b/sides329499276.html
51sole.com/b2b/sides359430124.html
51sole.com/b2b/sides304814237.html
51sole.com/b2b/sides330231983.html
51sole.com/b2b/sides359430343.html
51sole.com/b2b/sides359430537.html
51sole.com/b2b/sides359430748.html
51sole.com/b2b/sides329995715.html
51sole.com/b2b/sides359430778.html
51sole.com/b2b/sides359430965.html
51sole.com/b2b/sides359431019.html
51sole.com/b2b/sides359431072.html
51sole.com/b2b/sides359431175.html
51sole.com/b2b/sides329576786.html
51sole.com/b2b/sides303999622.html
51sole.com/b2b/sides359431365.html
51sole.com/b2b/sides359431470.html
51sole.com/b2b/sides303908374.html
51sole.com/b2b/sides359431520.html
51sole.com/b2b/sides359431552.html
51sole.com/b2b/sides359431681.html
51sole.com/b2b/sides329367930.html
51sole.com/b2b/sides359431726.html
51sole.com/b2b/sides303689390.html
51sole.com/b2b/sides359431894.html
51sole.com/b2b/sides329220129.html
51sole.com/b2b/sides359432030.html
51sole.com/b2b/sides359432070.html
51sole.com/b2b/sides329096064.html
51sole.com/b2b/sides359432220.html
51sole.com/b2b/sides359432256.html
51sole.com/b2b/sides359432305.html
51sole.com/b2b/sides329089122.html
51sole.com/b2b/sides359432425.html
51sole.com/b2b/sides359432454.html
51sole.com/b2b/sides359432657.html
51sole.com/b2b/sides359432659.html
51sole.com/b2b/sides359432699.html
51sole.com/b2b/sides359432898.html
51sole.com/b2b/sides359433182.html
51sole.com/b2b/sides359433240.html
51sole.com/b2b/sides329052926.html
51sole.com/b2b/sides304860243.html
51sole.com/b2b/sides359433545.html
51sole.com/b2b/sides303291840.html
51sole.com/b2b/sides328917940.html
51sole.com/b2b/sides359433742.html
51sole.com/b2b/sides359433843.html
51sole.com/b2b/sides328773985.html
51sole.com/b2b/sides303116863.html
51sole.com/b2b/sides359433997.html
51sole.com/b2b/sides328700820.html
51sole.com/b2b/sides359434216.html
51sole.com/b2b/sides302830474.html
51sole.com/b2b/sides328538229.html
51sole.com/b2b/sides359434457.html
51sole.com/b2b/sides328447581.html
51sole.com/b2b/sides359434716.html
51sole.com/b2b/sides328376142.html
51sole.com/b2b/sides302426565.html
51sole.com/b2b/sides359434963.html
51sole.com/b2b/sides328325886.html
51sole.com/b2b/sides302285649.html
51sole.com/b2b/sides359435211.html
51sole.com/b2b/sides328253789.html
51sole.com/b2b/sides302053310.html
51sole.com/b2b/sides359435470.html
51sole.com/b2b/sides359435628.html
51sole.com/b2b/sides359435718.html
51sole.com/b2b/sides301984644.html
51sole.com/b2b/sides359435961.html
51sole.com/b2b/sides327657133.html
51sole.com/b2b/sides301876592.html
51sole.com/b2b/sides359436198.html
51sole.com/b2b/sides359436230.html
51sole.com/b2b/sides301669389.html
51sole.com/b2b/sides330371559.html
51sole.com/b2b/sides359436437.html
51sole.com/b2b/sides359436453.html
51sole.com/b2b/sides301574920.html
51sole.com/b2b/sides359436676.html
51sole.com/b2b/sides359436806.html
51sole.com/b2b/sides359436942.html
51sole.com/b2b/sides359436971.html
51sole.com/b2b/sides359437046.html
51sole.com/b2b/sides359437080.html
51sole.com/b2b/sides359437190.html
51sole.com/b2b/sides359437246.html
51sole.com/b2b/sides359437294.html
51sole.com/b2b/sides359437370.html
51sole.com/b2b/sides359437449.html
51sole.com/b2b/sides359437530.html
51sole.com/b2b/sides359437542.html
51sole.com/b2b/sides359437719.html
51sole.com/b2b/sides326792353.html
51sole.com/b2b/sides359437976.html
51sole.com/b2b/sides301131910.html
51sole.com/b2b/sides326570550.html
51sole.com/b2b/sides359438308.html
51sole.com/b2b/sides301033742.html
51sole.com/b2b/sides326538754.html
51sole.com/b2b/sides359438637.html
51sole.com/b2b/sides326403598.html
51sole.com/b2b/sides300885165.html
51sole.com/b2b/sides359438976.html
51sole.com/b2b/sides359438996.html
51sole.com/b2b/sides300736115.html
51sole.com/b2b/sides359439301.html
51sole.com/b2b/sides359439314.html
51sole.com/b2b/sides359439582.html
51sole.com/b2b/sides300629258.html
51sole.com/b2b/sides359439790.html
51sole.com/b2b/sides359439853.html
51sole.com/b2b/sides300562389.html
51sole.com/b2b/sides359440044.html
51sole.com/b2b/sides359440130.html
51sole.com/b2b/sides300422293.html
51sole.com/b2b/sides359440285.html
51sole.com/b2b/sides359440387.html
51sole.com/b2b/sides300330549.html
51sole.com/b2b/sides359440537.html
51sole.com/b2b/sides359440655.html
51sole.com/b2b/sides325527073.html
51sole.com/b2b/sides359440914.html
51sole.com/b2b/sides300111569.html
51sole.com/b2b/sides359441164.html
51sole.com/b2b/sides359441197.html
51sole.com/b2b/sides324881038.html
51sole.com/b2b/sides359441481.html
51sole.com/b2b/sides359441598.html
51sole.com/b2b/sides359441747.html
51sole.com/b2b/sides359441834.html
51sole.com/b2b/sides359441894.html
51sole.com/b2b/sides359442006.html
51sole.com/b2b/sides359442084.html
51sole.com/b2b/sides359442198.html
51sole.com/b2b/sides359442285.html
51sole.com/b2b/sides359442351.html
51sole.com/b2b/sides359442489.html
51sole.com/b2b/sides359442550.html
51sole.com/b2b/sides359442621.html
51sole.com/b2b/sides359442795.html
51sole.com/b2b/sides359442880.html
51sole.com/b2b/sides359442995.html
51sole.com/b2b/sides359443099.html
51sole.com/b2b/sides359443140.html
51sole.com/b2b/sides359443398.html
51sole.com/b2b/sides359443405.html
51sole.com/b2b/sides359443452.html
51sole.com/b2b/sides359443665.html
51sole.com/b2b/sides359443724.html
51sole.com/b2b/sides359443796.html
51sole.com/b2b/sides298769914.html
51sole.com/b2b/sides359443941.html
51sole.com/b2b/sides359444003.html
51sole.com/b2b/sides359444095.html
51sole.com/b2b/sides321006962.html
51sole.com/b2b/sides359444272.html
51sole.com/b2b/sides320912230.html
51sole.com/b2b/sides359444551.html
51sole.com/b2b/sides359444575.html
51sole.com/b2b/sides359444815.html
51sole.com/b2b/sides359444875.html
51sole.com/b2b/sides359445087.html
51sole.com/b2b/sides359445130.html
51sole.com/b2b/sides359445256.html
51sole.com/b2b/sides359445396.html
51sole.com/b2b/sides359445496.html
51sole.com/b2b/sides359445547.html
51sole.com/b2b/sides359445802.html
51sole.com/b2b/sides320188039.html
51sole.com/b2b/sides298152448.html
51sole.com/b2b/sides314663527.html
51sole.com/b2b/sides314503538.html
51sole.com/b2b/sides298043619.html
51sole.com/b2b/sides314141573.html
51sole.com/b2b/sides359446788.html
51sole.com/b2b/sides359446924.html
51sole.com/b2b/sides359447137.html
51sole.com/b2b/sides359447319.html
51sole.com/b2b/sides313721016.html
51sole.com/b2b/sides359447517.html
51sole.com/b2b/sides313551109.html
51sole.com/b2b/sides359447707.html
51sole.com/b2b/sides297700560.html
51sole.com/b2b/sides313537980.html
51sole.com/b2b/sides359447913.html
51sole.com/b2b/sides359448394.html
51sole.com/b2b/sides359449261.html
51sole.com/b2b/sides359449439.html
51sole.com/b2b/sides297667198.html
51sole.com/b2b/sides313382042.html
51sole.com/b2b/sides297653443.html
51sole.com/b2b/sides313239475.html
51sole.com/b2b/sides297643211.html
51sole.com/b2b/sides359450248.html
51sole.com/b2b/sides359450416.html
51sole.com/b2b/sides297620927.html
51sole.com/b2b/sides297600457.html
51sole.com/b2b/sides359450808.html
51sole.com/b2b/sides359450982.html
51sole.com/b2b/sides297570568.html
51sole.com/b2b/sides359451274.html
51sole.com/b2b/sides359451445.html
51sole.com/b2b/sides359451622.html
51sole.com/b2b/sides359451801.html
51sole.com/b2b/sides297451589.html
51sole.com/b2b/sides359451987.html
51sole.com/b2b/sides297443627.html
51sole.com/b2b/sides359452152.html
51sole.com/b2b/sides359452174.html
51sole.com/b2b/sides297437027.html
51sole.com/b2b/sides359452476.html
51sole.com/b2b/sides359452693.html
51sole.com/b2b/sides297429285.html
51sole.com/b2b/sides359453059.html
51sole.com/b2b/sides297407088.html
51sole.com/b2b/sides359453312.html
51sole.com/b2b/sides297379694.html
51sole.com/b2b/sides359453596.html
51sole.com/b2b/sides297355849.html
51sole.com/b2b/sides359453628.html
51sole.com/b2b/sides359453757.html
51sole.com/b2b/sides359454025.html
51sole.com/b2b/sides297237378.html
51sole.com/b2b/sides297229804.html
51sole.com/b2b/sides297166259.html
