手痒系列,这个监控摄像头跟了我 十几年 年了,最近老是灰尘太多导致高温,干脆拆开研究一下,实在不行就当练练手。工具都准备好了,示波器、撬片、镊子一应俱全,开工。
拆之前先拍个照记一下螺丝位置,正面两颗藏在脚垫下面,撕开脚垫才能看到,藏得挺隐蔽。脚垫是用双面胶粘的,撕的时候小心点,后面还能粘回去。
掀开外壳,内部的STC 单片机比较显眼,周围一圈钽电容,看着不像是山寨货。芯片丝印还算清晰,没有被刻意打磨的痕迹,这一点比很多同价位产品要实在。
现象是灰尘太多导致高温,有时候拍一下又好了,典型的虚焊或者接触不良表现。这种问题最难找,肉眼基本看不出来,只能靠万用表逐点测量,配合按压法慢慢缩小范围。
逐个测了一遍,问题出在灰尘太多导致高温上,元件本身没坏,是引脚那边接触不良。拆下来重新上锡,顺便把周边几个疑似虚焊的点也补了一遍,防患于未然。
顺手把散热硅脂也换了,这玩意儿时间长了容易干,影响散热,换了之后温度明显低了不少。原来的硅脂已经硬得像块饼干,难怪会灰尘太多导致高温,散热不好元件寿命肯定受影响。
装回去之后连续通电测试了两个小时,灰尘太多导致高温没有再出现,19V 输出也稳定,说明问题确实解决了。中途特意加大负载试了一下,电压波动在正常范围内,可以放心用了。
折腾了一晚上,总算修好了,虽然不是什么值钱的玩意儿,但动手的乐趣就在这儿。从灰尘太多导致高温到满血复活,整个过程记录下来,也算给后来人留个参考。
拆机过程拍了不少图,回头整理一下补上,先发文字占个楼,大家先将就看。
https://www.51sole.com/b2b/sides358975084.html
https://www.51sole.com/b2b/sides358975087.html
https://www.51sole.com/b2b/sides358975132.html
https://www.51sole.com/b2b/sides358975158.html
https://www.51sole.com/b2b/sides358975222.html
https://www.51sole.com/b2b/sides358975254.html
https://www.51sole.com/b2b/sides358975269.html
https://www.51sole.com/b2b/sides358975327.html
https://www.51sole.com/b2b/sides358975378.html
https://www.51sole.com/b2b/sides358975435.html
https://www.51sole.com/b2b/sides358975486.html
https://www.51sole.com/b2b/sides358975538.html
https://www.51sole.com/b2b/sides358975597.html
https://www.51sole.com/b2b/sides358975648.html
https://www.51sole.com/b2b/sides358975716.html
https://www.51sole.com/b2b/sides358975779.html
https://www.51sole.com/b2b/sides358975844.html
https://www.51sole.com/b2b/sides358975981.html
https://www.51sole.com/b2b/sides358976003.html
https://www.51sole.com/b2b/sides358976112.html
https://www.51sole.com/b2b/sides358976199.html
https://www.51sole.com/b2b/sides358976290.html
https://www.51sole.com/b2b/sides358976303.html
https://www.51sole.com/b2b/sides358976387.html
https://www.51sole.com/b2b/sides358976398.html
https://www.51sole.com/b2b/sides358976476.html
https://www.51sole.com/b2b/sides358976487.html
https://www.51sole.com/b2b/sides358976563.html
https://www.51sole.com/b2b/sides358976657.html
https://www.51sole.com/b2b/sides358976685.html
https://www.51sole.com/b2b/sides358976722.html
https://www.51sole.com/b2b/sides358976762.html
https://www.51sole.com/b2b/sides358976807.html
https://www.51sole.com/b2b/sides358976837.html
https://www.51sole.com/b2b/sides358976891.html
https://www.51sole.com/b2b/sides358977028.html
https://www.51sole.com/b2b/sides358977126.html
https://www.51sole.com/b2b/sides358977172.html
https://www.51sole.com/b2b/sides358977277.html
https://www.51sole.com/b2b/sides358977323.html
https://www.51sole.com/b2b/sides358977434.html
https://www.51sole.com/b2b/sides358977481.html
https://www.51sole.com/b2b/sides358977594.html
https://www.51sole.com/b2b/sides358977648.html
https://www.51sole.com/b2b/sides358977772.html
https://www.51sole.com/b2b/sides358977827.html
https://www.51sole.com/b2b/sides358977990.html
https://www.51sole.com/b2b/sides358978043.html
https://www.51sole.com/b2b/sides358978810.html
https://www.51sole.com/b2b/sides358979004.html
https://www.51sole.com/b2b/sides358979169.html
https://www.51sole.com/b2b/sides358979361.html
https://www.51sole.com/b2b/sides358979499.html
https://www.51sole.com/b2b/sides358979845.html
https://www.51sole.com/b2b/sides358979997.html
https://www.51sole.com/b2b/sides358980214.html
https://www.51sole.com/b2b/sides358980373.html
https://www.51sole.com/b2b/sides358980519.html
https://www.51sole.com/b2b/sides358980683.html
https://www.51sole.com/b2b/sides358980837.html
https://www.51sole.com/b2b/sides358980997.html
https://www.51sole.com/b2b/sides358981170.html
https://www.51sole.com/b2b/sides358981378.html
https://www.51sole.com/b2b/sides358981577.html
https://www.51sole.com/b2b/sides358981753.html
https://www.51sole.com/b2b/sides358981946.html
https://www.51sole.com/b2b/sides358982104.html
https://www.51sole.com/b2b/sides358982233.html
https://www.51sole.com/b2b/sides358982341.html
https://www.51sole.com/b2b/sides358982458.html
https://www.51sole.com/b2b/sides358982560.html
https://www.51sole.com/b2b/sides358982682.html
https://www.51sole.com/b2b/sides358982794.html
https://www.51sole.com/b2b/sides358982899.html
https://www.51sole.com/b2b/sides358983120.html
https://www.51sole.com/b2b/sides358983349.html
https://www.51sole.com/b2b/sides358983594.html
https://www.51sole.com/b2b/sides358983802.html
https://www.51sole.com/b2b/sides359028008.html
https://www.51sole.com/b2b/sides184569256.html
https://www.51sole.com/b2b/sides359028031.html
https://www.51sole.com/b2b/sides359028056.html
https://www.51sole.com/b2b/sides359028095.html
https://www.51sole.com/b2b/sides359028141.html
https://www.51sole.com/b2b/sides359028183.html
https://www.51sole.com/b2b/sides359028228.html
https://www.51sole.com/b2b/sides359028315.html
https://www.51sole.com/b2b/sides359028350.html
https://www.51sole.com/b2b/sides359028392.html
https://www.51sole.com/b2b/sides359028436.html
https://www.51sole.com/b2b/sides359028473.html
https://www.51sole.com/b2b/sides359028495.html
https://www.51sole.com/b2b/sides359028515.html
https://www.51sole.com/b2b/sides359028539.html
https://www.51sole.com/b2b/sides359028561.html
https://www.51sole.com/b2b/sides359028581.html
https://www.51sole.com/b2b/sides359028600.html
https://www.51sole.com/b2b/sides359028623.html
https://www.51sole.com/b2b/sides359028657.html
https://www.51sole.com/b2b/sides359028687.html
https://www.51sole.com/b2b/sides359028727.html
https://www.51sole.com/b2b/sides359028764.html
https://www.51sole.com/b2b/sides359028799.html
https://www.51sole.com/b2b/sides359028816.html
https://www.51sole.com/b2b/sides359028842.html
https://www.51sole.com/b2b/sides359028852.html
https://www.51sole.com/b2b/sides359028861.html
https://www.51sole.com/b2b/sides359028872.html
https://www.51sole.com/b2b/sides359028900.html
https://www.51sole.com/b2b/sides359028913.html
https://www.51sole.com/b2b/sides359028926.html
https://www.51sole.com/b2b/sides359028944.html
https://www.51sole.com/b2b/sides359028959.html
https://www.51sole.com/b2b/sides359028979.html
https://www.51sole.com/b2b/sides359029001.html
https://www.51sole.com/b2b/sides359029022.html
https://www.51sole.com/b2b/sides359029048.html
https://www.51sole.com/b2b/sides359029083.html
https://www.51sole.com/b2b/sides359029105.html
https://www.51sole.com/b2b/sides359029123.html
https://www.51sole.com/b2b/sides359029139.html
https://www.51sole.com/b2b/sides359029155.html
https://www.51sole.com/b2b/sides359029169.html
https://www.51sole.com/b2b/sides359029184.html
https://www.51sole.com/b2b/sides359029381.html
https://www.51sole.com/b2b/sides359029402.html
https://www.51sole.com/b2b/sides305436969.html
https://www.51sole.com/b2b/sides359029440.html
https://www.51sole.com/b2b/sides359029672.html
https://www.51sole.com/b2b/sides359029709.html
https://www.51sole.com/b2b/sides359029752.html
https://www.51sole.com/b2b/sides359029889.html
https://www.51sole.com/b2b/sides359029927.html
https://www.51sole.com/b2b/sides359029975.html
https://www.51sole.com/b2b/sides359030060.html
https://www.51sole.com/b2b/sides359030095.html
https://www.51sole.com/b2b/sides359030199.html
https://www.51sole.com/b2b/sides359030239.html
https://www.51sole.com/b2b/sides359030245.html
https://www.51sole.com/b2b/sides359030334.html
https://www.51sole.com/b2b/sides359030347.html
https://www.51sole.com/b2b/sides359030371.html
https://www.51sole.com/b2b/sides359030470.html
https://www.51sole.com/b2b/sides359030493.html
https://www.51sole.com/b2b/sides359030499.html
https://www.51sole.com/b2b/sides359030509.html
https://www.51sole.com/b2b/sides359030632.html
https://www.51sole.com/b2b/sides359030634.html
https://www.51sole.com/b2b/sides359030653.html
https://www.51sole.com/b2b/sides359030704.html
https://www.51sole.com/b2b/sides359030745.html
https://www.51sole.com/b2b/sides359030752.html
https://www.51sole.com/b2b/sides359030755.html
https://www.51sole.com/b2b/sides359030827.html
https://www.51sole.com/b2b/sides359030860.html
https://www.51sole.com/b2b/sides359030866.html
https://www.51sole.com/b2b/sides359030886.html
https://www.51sole.com/b2b/sides359030956.html
https://www.51sole.com/b2b/sides359030958.html
https://www.51sole.com/b2b/sides359030977.html
https://www.51sole.com/b2b/sides359031041.html
https://www.51sole.com/b2b/sides359031069.html
https://www.51sole.com/b2b/sides359031135.html
https://www.51sole.com/b2b/sides359031175.html
https://www.51sole.com/b2b/sides359031189.html
https://www.51sole.com/b2b/sides359031233.html
https://www.51sole.com/b2b/sides359031236.html
https://www.51sole.com/b2b/sides359031280.html
https://www.51sole.com/b2b/sides359031281.html
https://www.51sole.com/b2b/sides359031317.html
https://www.51sole.com/b2b/sides359031322.html
https://www.51sole.com/b2b/sides359031343.html
https://www.51sole.com/b2b/sides359031355.html
https://www.51sole.com/b2b/sides359031385.html
https://www.51sole.com/b2b/sides359031391.html
https://www.51sole.com/b2b/sides359031423.html
https://www.51sole.com/b2b/sides359031436.html
https://www.51sole.com/b2b/sides359031448.html
https://www.51sole.com/b2b/sides359031457.html
https://www.51sole.com/b2b/sides359031483.html
https://www.51sole.com/b2b/sides359031492.html
https://www.51sole.com/b2b/sides359031500.html
https://www.51sole.com/b2b/sides359031521.html
https://www.51sole.com/b2b/sides359031543.html
https://www.51sole.com/b2b/sides359031549.html
https://www.51sole.com/b2b/sides359031565.html
https://www.51sole.com/b2b/sides359031594.html
https://www.51sole.com/b2b/sides359031603.html
https://www.51sole.com/b2b/sides359031608.html
https://www.51sole.com/b2b/sides359031648.html
https://www.51sole.com/b2b/sides359031651.html
https://www.51sole.com/b2b/sides359031667.html
https://www.51sole.com/b2b/sides359031669.html
https://www.51sole.com/b2b/sides359031708.html
https://www.51sole.com/b2b/sides359031738.html
https://www.51sole.com/b2b/sides359031765.html
https://www.51sole.com/b2b/sides359031785.html
https://www.51sole.com/b2b/sides359031850.html
https://www.51sole.com/b2b/sides359031897.html
https://www.51sole.com/b2b/sides359031940.html
https://www.51sole.com/b2b/sides359031973.html
https://www.51sole.com/b2b/sides359031985.html
