查看: 1631|回复: 1
[C51] 通用型1602液晶屏用一组I/O口控制程序
发表于 2019-9-28 14:00:57 | 显示全部楼层 |阅读模式
最近在写数字表头的程序时,试试四线数据传输给1602液晶屏,效果还可以,对于实时要求不高的场合效果还不错。这两个程序通过了STC15W408AS单片机系统的验证,主频11.0592NHz时。请坛友指正!
#ifndef __LCD1602_H__
#define __LCD1602_H__
unsigned char bdata C;  //在位寻址区定义字符变量C
sbit C7=C^7;
sbit C6=C^6;
sbit C5=C^5;
sbit C4=C^4;
sbit C3=C^3;
sbit C2=C^2;
sbit C1=C^1;
sbit C0=C^0;
sbit RS=P1^1;
sbit RW=P1^2;
sbit EN=P1^3;
sbit I4=P1^4;
sbit I5=P1^5;
sbit I6=P1^6;
sbit I7=P1^7;
/****************延时***************/
void delay_ms(unsigned int i)
  unsigned int t;
while(i--)
  for(t=0;t<123;t++);
/***用LCD1602高四位数据线写入命令**/
void write_com(unsigned char command)
  C=command;
  RS=0;
RW=0;
EN=0;   //写命令
delay_ms(1);
I7=C7;
I6=C6;
I5=C5;
I4=C4;
EN=1;
delay_ms(6); //延时
EN=0;   //下降沿将数据写入LCD1602
delay_ms(1);
I7=C3;
I6=C2;
I5=C1;
I4=C0;
EN=1;
delay_ms(1); //延时
/**用LCD1602高四位数据线写入数据**/
void write_dat(unsigned char dat)
  C=dat;
  RS=1;
RW=0;
EN=0;
delay_ms(1);
I7=C7;
I6=C6;
I5=C5;
I4=C4;
EN=1;
delay_ms(6);  //延时
EN=0;
delay_ms(1);
I7=C3;
I6=C2;
I5=C1;
I4=C0;
EN=1;
    delay_ms(1);  //延时
EN=0;
/********LCD1602初始化*************/
void LCD_init(void)
  write_com(0x02);
write_com(0x28);
write_com(0x0c);
write_com(0x80);
write_com(0x01);  //清屏
/*******设置LCD1602列、行**********/
void LCD_sor(unsigned char x,unsigned y)
  unsigned char address;
if(y==0)
  address=0x80+x;
else
  address=0xC0+x;
write_com(address);
void LCD_str(unsigned x,unsigned char y,unsigned char *str)
  LCD_sor(x,y);
while((*str)!='\0')
  write_dat(*str);
  str++;
  #endif
另一种方式:
unsigned char C;
  unsigned int t;
while(i--)
  for(t=0;t<123;t++);
  unsigned char dat;
  C=command;
dat=C&0xF0;     //屏蔽数据低四位
P1=0x00;     //1602三个使能端低电平
delay_ms(1);
P1=dat|0x08;     //1602使能端EN高电平
delay_ms(6); //延时
P1=dat|0x00;     //1602使能端EN下降沿将数据写入LCD1602
delay_ms(1);
dat=C&0x0F;     //屏蔽数据高四位
dat=dat<<4;     //移位至高四位
delay_ms(1); //延时
  unsigned char a;
  C=dat;
a=C&0xF0;      //分离高四位
P1=0x02;
delay_ms(1);
P1=a|0x0A;
delay_ms(6);  //延时
P1=a|0x02;
delay_ms(1);
a=C&0x0F;
a=a<<4;
P1=a|0x0A;
    delay_ms(1);  //延时
P1=a|0x02;
void LCD_init(void)
  write_com(0x02);
write_com(0x28);
write_com(0x0c);
write_com(0x80);
if(y==0)
  address=0x80+x;
else
  address=0xC0+x;
write_com(address);
  LCD_sor(x,y);
while((*str)!='\0')
  write_dat(*str);
  str++;
  #endif
参与人数 1家元 +20 收起 理由
家睦 + 20
发表于 2019-9-28 14:37:50 | 显示全部楼层
GMT+8, 2025-12-29 02:07 , Processed in 0.249600 second(s), 12 queries , Gzip On, Redis On.
