楼下捡的,
哪个熊孩子残忍的剥光了它的衣服,掰断了胳膊。
美人头模具做的还不错。
开拆
扬声器一个
电路板,
转身电机
牛屎亮
TC117
TCH117 直流马达驱动IC,SOP8 ,内置 MOS桥 驱动电路,驱动电流大,自带刹车功能
FLASH
FL216KIE
2M的闪存?
The S25FL216K device is a 16-Mbit, 2048-kbyte Serial Flash memory, with advanced write protection mechanisms. The S25FL216K supports the standard Serial Peripheral Interface (SPI), and a high performance Dual output using SPI pins: Serial Clock, Chip Select, Serial SI/IO0, SO, WP#, and HOLD#. SPI clock frequencies of up to 65 MHz are supported.
这个没查到资料,看电路应该是个 遥控射频解码芯片?
拆解得到的东西如图。好像还有点小用,也许是攒着吃灰。
