软件截图更新日志VirtualBox 7.0.6 (released January 17 2023) This is a maintenance release. The following items were fixed and/or added: - VMM: Fixed guru running the FreeBSD loader on older Intel CPUs without unrestricted guest support
- GUI: Fixed virtual machines grouping when VM was created or modified in command line
- GUI: Introduced generic changes in settings dialogs
- VirtioNet: Fixed broken network after loading saved state
- Storage: Added support for increasing the size of the following VMDK image variants: monolithicFlat, monolithicSparse, twoGbMaxExtentSparse, twoGbMaxExtentFlat
- VBoxManage: Added missing --directory switch for guestcontrol mktemp command
- Mouse Integration: Guest was provided with extended host mouse state
- DnD: Introduced generic improvements
- Guest Control: Fixed handling creation mode for temporary directories
- Linux Host and Guest: Added initial support for building UEK7 kernel on Oracle Linux 8
- Linux Host and Guest: Added initial support for RHEL 9.1 kernel
- Windows Host: Fixed support for VM autostart
- Linux Guest Additions: Added initial support for kernel 6.2 for vboxvideo
- Audio: The "--audio" option in VBoxManage is now marked as deprecated; please use "--audio-driver" and "--audio-enabled" instead. This will allow more flexibility when changing the driver and/or controlling the audio functionality
下载地址
