查看: 2123|回复: 6
[SandForce] SF2281 开卡跳线设置CE识别不对失败求助
发表于 2023-5-7 15:56:40 | 显示全部楼层 |阅读模式
首先对查看的各路老师大神表示感谢,感谢百忙之中提供帮助;
接上期之前搞了一批小固态硬盘:(请教东芝恺侠的SLC颗粒TH58TAG6S2FBA89这种该如何利用
https://www.mydigit.cn/forum.php?mod=viewthread&tid=340938&fromuid=1629377
最终定了使用SF2281 16贴的板子方案;托朋友搞了一块回来尝试改装,空板测试都正常;
板子如下图:于是贴上颗粒如下图16位贴满 TH58TAG6S2FBA89  单颗4CE 使用22724 开遇到CE识别不对的问题
ce跳线使用 R116 R121 R122 R123 R118
是如下识别:
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 2    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 3    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 4    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 4    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 4    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 4    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 5    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 5    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 5    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 5    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 6    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 6    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 0    | 6    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 6    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 0    | 7    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 0    | 7    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 7    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 0    | 7    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 2    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 2    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 2    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 2    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 3    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 3    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 3    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 3    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 4    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 4    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 4    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 4    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 5    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 5    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 5    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 5    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 6    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 6    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 6    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 6    | 0    | 3    | 0x0001 | N1                                         |    PASS |
| 1    | 7    | 0    | 0    | 0x0001 | N1                                         |    PASS |
| 1    | 7    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 7    | 0    | 2    | 0x0001 | N1                                         |    PASS |
| 1    | 7    | 0    | 3    | 0x0001 | N1                                         |    PASS |
ce跳线使用 R116 R121 R123 R118
是如下
| 0    | 6    | 0    | 1    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 0    | 6    | 0    | 3    | 0x0374 | N4,N5,N6,N8,N10                            |    FAIL |
| 1    | 6    | 0    | 1    | 0x0001 | N1                                         |    PASS |
| 1    | 7    | 0    | 1    | 0x0001 | N1                                         |    PASS |
经过几次反复移动发现还是这几个识别不对,实在头大,特发此贴求助大神这个板子跳线是不是改的不对;还望指正,小弟万分感谢;
发表于 2023-5-7 17:47:06 | 显示全部楼层
发表于 2023-5-7 17:53:40 | 显示全部楼层
 楼主| 发表于 2023-5-9 17:23:51 | 显示全部楼层
发表于 2023-5-9 18:55:22 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2023-5-9 23:45:41 | 显示全部楼层
 楼主| 发表于 2023-5-9 23:52:08 | 显示全部楼层
GMT+8, 2026-10-23 22:30 , Processed in 0.140400 second(s), 11 queries , Gzip On, Redis On.
