查看: 2157|回复: 27
[Arduino] ATmega16写入bootloader,仍然无法在Arduino用串口方式下载
发表于 2024-5-2 08:19:05 | 显示全部楼层 |阅读模式
ATmega16老板子,8MHz晶振,焊线接出ISP下载接口与AVR-ISP下载器对接,通过Arduino下载启动程序。
下载启动程序时开发板设置:
下载结果如下:
avrdude: Version 7.2-arduino.1
         Copyright the AVRDUDE authors;
         see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
         System wide configuration file is C:\Arduino\portable\packages\MightyCore\hardware\avr\3.0.1\avrdude.conf
         Using Port                    : usb
         Using Programmer              : usbasp
         AVR Part                      : ATmega16
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         Serial program mode           : yes
         Parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                           Block Poll               Page                       Polled
           Memory Type Alias    Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom                  4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
           flash                  33    10   128    0 yes     16384  128    128  4500  4500 0xff 0x00
           lfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           hfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           lock                    0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           signature               0     0     0    0 no          3    1      0     0     0 0x00 0x00
           calibration             0     0     0    0 no          4    1      0     0     0 0x00 0x00
         Programmer Type : usbasp
         Description     : USBasp ISP and TPI programmer
avrdude: auto set sck period (because given equals null)
avrdude usbasp_spi_set_sck_period() error: cannot set sck period; please check for usbasp firmware update
avrdude: AVR device initialized and ready to accept instructions
avrdude: device signature = 0x1e9403 (probably m16)
avrdude: erasing chip
avrdude: processing -U lock:w:0xff:m
avrdude: reading input file 0xff for lock
         with 1 byte in 1 section within [0, 0]
avrdude: writing 1 byte lock ...
avrdude: 1 byte of lock written
avrdude: verifying lock memory against 0xff
avrdude: 1 byte of lock verified
avrdude: processing -U efuse:w:{bootloader.extended_fuses}:m
avrdude do_op() warning: skipping -U efuse:... as memory not defined for part ATmega16
avrdude: processing -U hfuse:w:0b11000111:m
avrdude: reading input file 0b11000111 for hfuse
avrdude: writing 1 byte hfuse ...
avrdude: 1 byte of hfuse written
avrdude: verifying hfuse memory against 0b11000111
avrdude: 1 byte of hfuse verified
avrdude: processing -U lfuse:w:0b10111111:m
avrdude: reading input file 0b10111111 for lfuse
avrdude: writing 1 byte lfuse ...
avrdude: 1 byte of lfuse written
avrdude: verifying lfuse memory against 0b10111111
avrdude: 1 byte of lfuse verified
avrdude done.  Thank you.
C:\Arduino\portable\packages\MightyCore\tools\avrdude\7.2-arduino.1/bin/avrdude -CC:\Arduino\portable\packages\MightyCore\hardware\avr\3.0.1/avrdude.conf -v -patmega16 -cusbasp -Uflash:w:C:\Arduino\portable\packages\MightyCore\hardware\avr\3.0.1/bootloaders/empty/empty.hex:i -Ulock:w:0xff:m
         Using Port                    : usb
         AVR Part                      : ATmega16
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
avrdude: Note: flash memory has been specified, an erase cycle will be performed.
         To disable this feature, specify the -D option.
avrdude: processing -U flash:w:C:\Arduino\portable\packages\MightyCore\hardware\avr\3.0.1/bootloaders/empty/empty.hex:i
avrdude: reading input file C:\Arduino\portable\packages\MightyCore\hardware\avr\3.0.1/bootloaders/empty/empty.hex for flash
         with 0 bytes in 0 sections within [0, -1]
         using 0 pages and 0 pad bytes
avrdude: writing 0 bytes flash ...
Writing | ################################################## | 100% 0.00s
avrdude: 0 bytes of flash written
avrdude: verifying flash memory against C:\Arduino\portable\packages\MightyCore\hardware\avr\3.0.1/bootloaders/empty/empty.hex
Reading | ################################################## | 100% 0.00s
avrdude: 0 bytes of flash verified
而后拆下ISP下载器连接,将TX、RX接入CH340G的RX、TX,M16的RST通过100u接入CH340G的RTS,然后尝试下载Arduino程序,
用串口下载时,开发板设置:
结果如下:
         Using Port                    : COM21
         Using Programmer              : urclock
         Overriding Baud Rate          : 57600
avrdude urclock_getsync() warning: attempt 1 of 10: not in sync
avrdude urclock_getsync() warning: attempt 2 of 10: not in sync
avrdude urclock_getsync() warning: attempt 3 of 10: not in sync
avrdude urclock_getsync() warning: attempt 4 of 10: not in sync
avrdude urclock_getsync() warning: attempt 5 of 10: not in sync
avrdude urclock_getsync() warning: attempt 6 of 10: not in sync
avrdude urclock_getsync() warning: attempt 7 of 10: not in sync
avrdude urclock_getsync() warning: attempt 8 of 10: not in sync
avrdude urclock_getsync() warning: attempt 9 of 10: not in sync
avrdude urclock_getsync() warning: attempt 10 of 10: not in sync
avrdude urclock_recv() warning: programmer is not responding; try -xstrict and/or vary -xdelay=100
avrdude main() error: unable to open programmer urclock on port COM21
选择的串口
不存在或开发板没有连接
有尝试下面做法,均无效:
1、怀疑RXTX接错,对调无效。
2、M16在下载时碰GND进行人工复位,无效。
3、烧录启动程序时选择低波特率如9600、4800均无效。
为什么会出现这样的问题,难道M16不支持Arduino?请高手指教一下,谢谢!
发表于 2024-5-2 16:53:36 | 显示全部楼层
发表于 2024-5-2 21:03:22 | 显示全部楼层
发表于 2024-5-2 23:02:14 | 显示全部楼层
发表于 2024-5-3 13:21:56 | 显示全部楼层
 楼主| 发表于 2024-5-3 16:08:30 | 显示全部楼层
发表于 2024-5-3 18:22:47 | 显示全部楼层
发表于 2024-5-3 21:40:51 | 显示全部楼层
发表于 2024-5-3 21:46:34 | 显示全部楼层
 楼主| 发表于 2024-5-4 10:09:00 | 显示全部楼层
发表于 2024-5-4 12:02:33 | 显示全部楼层
发表于 2024-5-4 12:03:53 | 显示全部楼层
发表于 2024-5-5 18:29:05 | 显示全部楼层
 楼主| 发表于 2024-5-5 19:28:07 | 显示全部楼层
 楼主| 发表于 2024-5-5 19:30:05 | 显示全部楼层
发表于 2024-5-5 23:56:45 | 显示全部楼层
 楼主| 发表于 2024-5-6 08:03:51 | 显示全部楼层
发表于 2024-5-6 11:19:28 | 显示全部楼层
 楼主| 发表于 2024-5-6 11:40:45 | 显示全部楼层
发表于 2024-5-6 13:25:07 | 显示全部楼层
GMT+8, 2025-12-28 18:12 , Processed in 0.171601 second(s), 12 queries , Gzip On, Redis On.
