查看: 125|回复: 4
[C51] stc11f02e转速表 帮我看下这个程序是那里的问题
发表于 昨天 11:55 来自手机浏览器 | 显示全部楼层 |阅读模式
各位大师麻烦帮我看下这个程序是那里的问题,用stc11f02e做一个测量电机转速的转速表,现在4位数码管显示4个0正常,但一有转速脉冲就乱显基本显示几个固定的数字比如75   1160   3350  6600等,转速很低都乱显,用的是光电传感器,#include <reg51.h>
typedef unsigned char uchar;
typedef unsigned int uint;
typedef unsigned long ulong;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P3M1 = 0xB1;
sfr P3M0 = 0xB2;
sbit sel0 = P3^2;
sbit sel1 = P3^3;
sbit sel2 = P3^4;
sbit sel3 = P3^7;
sbit HALL_IN = P3^5;  //霍尔输入
uchar code seg[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
#define SEG_BLANK  0xFF
uchar disp_buf[4];
uint rpm = 0;
uint rpm_last = 0;
uchar scan_cnt = 0;
uint time_cnt = 0;
uint pulse_cnt = 0;
uint buf[8];
uchar buf_idx = 0;
bit calc_flag = 0;
bit hall_last = 1;
uchar hall_timer = 0;   //消抖计时
#define RPM_MAX  9999
#define STEP_LIMIT 150
#define HALL_TICK 10     //消抖需要的计时刻度
void short_delay(void)
    uchar i;
    for(i=5;i>0;i--);
void delay_ms(uint t)
    uint i,j;
    for(i=t;i>0;i--)
        for(j=110;j>0;j--);
void clear_filter_buf(void)
    uchar i;
    for(i=0;i<8;i++) buf=0;
    buf_idx = 0;
// T0 2ms定时,数码扫描 + 系统计时 11.0592M
void Timer0_Init(void)
    TMOD |= 0x01;
    TH0 = 0xF8;
    TL0 = 0x30;
    ET0 = 1;
    TR0 = 1;
    EA = 1;
uint filter(uint val)
    uint sum=0,i;
    buf[buf_idx++] = val;
    if(buf_idx>=8) buf_idx=0;
    for(i=0;i<8;i++) sum += buf;
    return sum>>3;
void calc_rpm()
    uint rpm_tmp;
    uint qian,bai,shi,ge;
    rpm_tmp = pulse_cnt * 600;
    if( (rpm_tmp > rpm_last + STEP_LIMIT) && (rpm_last != 0) )
        rpm_tmp = rpm_last;
    else
        rpm_last = rpm_tmp;
    rpm = filter(rpm_tmp);
    pulse_cnt = 0;
    if(rpm > RPM_MAX)
        disp_buf[0] = SEG_BLANK;
        disp_buf[1] = SEG_BLANK;
        disp_buf[2] = SEG_BLANK;
        disp_buf[3] = SEG_BLANK;
    else if(rpm == 0)
        disp_buf[0] = 0;
        disp_buf[1] = 0;
        disp_buf[2] = 0;
        disp_buf[3] = 0;
    else
        qian = rpm / 1000;
        bai  = (rpm / 100) % 10;
        shi  = (rpm / 10) % 10;
        ge   = rpm % 10;
        disp_buf[0] = qian;
        disp_buf[1] = bai;
        disp_buf[2] = shi;
        disp_buf[3] = ge;
        if(disp_buf[0]==0)
            disp_buf[0]=SEG_BLANK;
            if(disp_buf[1]==0)
                disp_buf[1]=SEG_BLANK;
void Timer0_ISR() interrupt 1
    TH0 = 0xF8;
    TL0 = 0x30;
    time_cnt++;
    //==== 无阻塞计时消抖捕获下降沿,中断里没有延时!====
    if(hall_timer > 0)
        hall_timer--;
    else
        if(hall_last == 1 && HALL_IN == 0)
            pulse_cnt++;
            hall_timer = HALL_TICK;  //锁定,一段时间内不再响应,防止连续误触发
        hall_last = HALL_IN;
    //数码管扫描
    sel0 = 1;
    sel1 = 1;
    sel2 = 1;
    sel3 = 1;
    P1 = 0x00;
    short_delay();
    if(disp_buf[scan_cnt] != SEG_BLANK)
        P1 = seg[disp_buf[scan_cnt]];
    else
        P1 = 0x00;
    short_delay();
    switch(scan_cnt)
        case 0: sel0 = 0; break;
        case 1: sel1 = 0; break;
        case 2: sel2 = 0; break;
        case 3: sel3 = 0; break;
    scan_cnt++;
    if(scan_cnt>=4) scan_cnt=0;
    if(time_cnt>=50)
        time_cnt=0;
        calc_flag = 1;
void IO_Init(void)
    P1M1 = 0x00;
    P1M0 = 0xFF;
    //位选脚推挽输出
    P3M1 &= ~((1<<2)|(1<<3)|(1<<4)|(1<<7));
    P3M0 |=  ((1<<2)|(1<<3)|(1<<4)|(1<<7));
    //P3.5 高阻输入,不推挽
    P3M1 &= ~(1<<5);
    P3M0 &= ~(1<<5);
void main(void)
    pulse_cnt = 0;
    time_cnt = 0;
    rpm_last = 0;
    hall_last = 1;
    hall_timer = 0;
    clear_filter_buf();
    IO_Init();
    delay_ms(600);
    Timer0_Init();
    while(1)
        if(calc_flag == 1)
            calc_flag = 0;
            calc_rpm();
发表于 昨天 13:00 | 显示全部楼层
发表于 昨天 18:03 来自手机浏览器 | 显示全部楼层
发表于 昨天 20:39 | 显示全部楼层
 楼主| 发表于 昨天 23:37 来自手机浏览器 | 显示全部楼层
GMT+8, 2026-10-25 08:55 , Processed in 0.109200 second(s), 10 queries , Gzip On, Redis On.
