查看: 944|回复: 0
[SandForce] 求助,sf2281开卡报错,提示好像是无法解压固件?
发表于 2023-3-22 10:38:34 | 显示全部楼层 |阅读模式
提示好像是无法解压固件?这个怎么破各位大神
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 03/22/2023 10:31:24] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 5:0:0:0
                      argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
                      argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/29563.12345.test.edriveconfig
                      argv[5]: 12345
                      argv[6]: www_123
                      argv[7]: log=/log/
[Wed 03/22/2023 10:31:24] - Instructing the operating system to purge any existing cached data for device: '5:0:0:0'
[Wed 03/22/2023 10:31:29] - Issuing a discovery command for device: '5:0:0:0'
[Wed 03/22/2023 10:31:34] - Discovery command completed...
[Wed 03/22/2023 10:31:34] - Waiting 5 seconds for the system to settle...
[Wed 03/22/2023 10:31:39] - Device designation string '5:0:0:0' is mapped to node '/dev/sg2'
[Wed 03/22/2023 10:31:39] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
      Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/29563.12345.test.edriveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Wed 03/22/2023 10:31:39] - Successfully received the IDENTIFY data from the drive...
[Wed 03/22/2023 10:31:39] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
[Wed 03/22/2023 10:31:39] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/FW_PPRO_5_8_2_Release.906190.release.12345.mfp
[Wed 03/22/2023 10:31:39] - File : /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/29563.12345.test.edriveconfig in processing ...
[Wed 03/22/2023 10:31:39] - file  /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/29563.12345.test.edriveconfig Loaded successfully
[Wed 03/22/2023 10:31:53] - Warning:  Unable to query diagnostics information to perform power management settings check
[Wed 03/22/2023 10:31:53] - B01 Power Management configuration request detected
[Wed 03/22/2023 10:31:53] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/29563.12345.test.edriveconfig
[Wed 03/22/2023 10:31:53] - Extracted Config_ID: 1 (29563) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_5_8_2_Release.906190.release--12345/Configuration_Files/29563.12345.test.edriveconfig
[Wed 03/22/2023 10:31:53] - Extracted SerialOutputControl: 0
[Wed 03/22/2023 10:31:53] - Searching for flashware image for configuration 29563
[Wed 03/22/2023 10:31:53] - FATAL_ERROR: Could not extract flashware image: 29563
[Wed 03/22/2023 10:31:53] - End of Genesis manufacturing log.
[Wed 03/22/2023 10:31:53] - Exiting...
[Wed 03/22/2023 10:31:53] - Overall Result for Device: /dev/sg2 ****** FAIL ******
GMT+8, 2026-10-24 02:31 , Processed in 0.156001 second(s), 11 queries , Gzip On, Redis On.
