查看: 535|回复: 7
[SandForce] sf2281 4贴东芝7s2f量产失败 大佬看看怎么回事
发表于 2026-5-17 11:58:32 来自手机浏览器 | 显示全部楼层 |阅读模式
[root@localhost SF_Genesis-v1.7]# ./SF_Genesis -PROCESS_SSD 11:0:0:0 '/root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp' '/root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22127.12345.test.edriveconfig' 12345 www_123 log=/log/~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~  SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit  SF_Core Library: v1.7.1.20130612-fc14-32bit  Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [Sun 05/17/2026 11:43:40] - SF_Genesis has been invoked with the following parameters:                     ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~                      argv[1]: -PROCESS_SSD                      argv[2]: 11:0:0:0                      argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp                      argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22127.12345.test.edriveconfig                      argv[5]: 12345                      argv[6]: www_123                      argv[7]: log=/log/                     ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~[Sun 05/17/2026 11:43:40] - Instructing the operating system to purge any existing cached data for device: '11:0:0:0'[Sun 05/17/2026 11:43:45] - Issuing a discovery command for device: '11:0:0:0'[Sun 05/17/2026 11:43:50] - Discovery command completed...[Sun 05/17/2026 11:43:50] - Waiting 5 seconds for the system to settle...[Sun 05/17/2026 11:43:55] - Device designation string '11:0:0:0' is mapped to node '/dev/sg2'[Sun 05/17/2026 11:43:55] - Proceeding to process SSD device with the following parameters:  ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~              DeviceName = /dev/sg2    MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp      Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22127.12345.test.edriveconfig              Serial No. = 12345         World Wide Name = www_123  ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~[Sun 05/17/2026 11:43:55] - Successfully received the IDENTIFY data from the drive...[Sun 05/17/2026 11:43:55] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp[Sun 05/17/2026 11:43:55] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp[Sun 05/17/2026 11:43:55] - File : /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22127.12345.test.edriveconfig in processing ... [Sun 05/17/2026 11:43:55] - file  /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22127.12345.test.edriveconfig Loaded successfully[Sun 05/17/2026 11:43:55] - Warning:  Unable to query diagnostics information to perform power management settings check[Sun 05/17/2026 11:43:55] - B01 Power Management configuration request detected[Sun 05/17/2026 11:43:55] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22127.12345.test.edriveconfig[Sun 05/17/2026 11:43:55] - Extracted Config_ID: 1 (22127) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/22127.12345.test.edriveconfig[Sun 05/17/2026 11:43:55] - Extracted SerialOutputControl: 0[Sun 05/17/2026 11:43:55] - Searching for flashware image for configuration 22127[Sun 05/17/2026 11:43:55] - Manifest found for configuration 22127[Sun 05/17/2026 11:43:55] - Flashware image extracted: 22127_fw_cl_slc_Toshiba_16Gb_TH58TAG7S2FBA89_2Q_2C_2D_PP_R00477_s512.vic[Sun 05/17/2026 11:43:55] - Searching for manufacturing image for configuration 22127[Sun 05/17/2026 11:43:55] - Manifest found for configuration 22127[Sun 05/17/2026 11:43:55] - Manufacturing image extracted: 22127_mf_slc_Toshiba_16Gb_TH58TAG7S2FBA89_2Q_2C_2D_PP_R00477_s512.vic[Sun 05/17/2026 11:43:55] - Proceeding in ROM mode, download feature 3...[Sun 05/17/2026 11:43:56] - Successfully downloaded MFB to the drive...[Sun 05/17/2026 11:43:56] - Waiting (5 sec) for the drive to settle...[Sun 05/17/2026 11:44:01] - Successfully received the IDENTIFY data from the drive...[Sun 05/17/2026 11:44:01] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.[Sun 05/17/2026 11:44:01] - Successfully enabled SMART capabilities...[Sun 05/17/2026 11:44:03] - Successfully issued a diagnostic unlock...[Sun 05/17/2026 11:44:04] - Performing the flash test of block 0 (0x0000)...[Sun 05/17/2026 11:44:06] - Flash Test Results:~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~----------------------------------------------------------------------------- Flash Test Parameters:                             -----------------------------------------------------------------------------               Block Count: 0                                      Page Count: 1                                       Bus Count: 2                              Chip Enabled Count: 2                                       Die Count: 2                                      Lane Count: 4                                     Plane Count: 2                      ----------------------------------------------------------------------------- Results Notes:                                      -----------------------                                 N1 - At least one page tested and passed with no bit errors.   N2 - No test data available.  Test may have aborted, or failed during the testing.   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.   N4 - At least  one erased page tested had bit error rate greater than half the correction power.   N5 - Walking zeros test failed.   N6 - Walking ones test failed.   N7 - Block contained factory bad block markings and testing was skipped.   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.   N9 - Block in plane 0 was marked as a factory bad block.  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.  N11 - Block in plane 1 was marked as a factory bad block.-----------------------------------------------------------------------------+------+------+------+------+--------+--------------------------------------------+---------+| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 1    | 0    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 1    | 1    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 1    | 2    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 0    | 1    | 3    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 1    | 0    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 1    | 1    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 1    | 2    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 0    | 1    | 1    | 3    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 0    | 0    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 0    | 1    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 0    | 2    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 0    | 3    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 1    | 0    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 1    | 1    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 1    | 2    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 0    | 1    | 3    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 0    | 0    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 0    | 1    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 0    | 2    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 0    | 3    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 1    | 0    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 1    | 1    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 1    | 2    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+| 1    | 1    | 1    | 3    | 0x0001 | N1                                         |    PASS |+------+------+------+------+--------+--------------------------------------------+---------+-----------------------------------------------------------------------------  Total Number of test results: 32                                  Number of failures: 0                               Number of Passed with warnings: 0                            No. Passed without warnings: 32                      -----------------------------------------------------------------------------~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~[Sun 05/17/2026 11:44:06] - Performing the FORMAT Command with the following parameters: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~         MemoryWearCycleCapability = 0               CurrentPE_CycleCount = 0                      LifeInSeconds = 0                    LogicalCapacity = 117231408                         SectorSize = 512              SectorAlignmentOffset = 0                   ExpectedMemoryID = 55192 (0xD798)                   ExpectedNumDies = 0                SerialOutputControl = 0                            Time[8] = 0x0000000000000000             MiscFlag_Erase_R_Block = 0      MiscFlag_PanicHandlingEnabled = 0         MiscFlag_PanicOnSATA_Error = 0   MiscFlag_WriteThrottlingTestMode = 0       MiscFlag_DisableUserBandECCX = 0                         L_PageSize = 0                         E_PageSize = 0               ErrorCorrectionPower = 0       ConfigDeviceReadDisturbCount = 0    ConfigDeviceReadDisturbCountLow = 0                   ExtraOptions_0_1 = 0 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~[Sun 05/17/2026 11:45:00] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x0000C048:SF_SCT (C048h): Root Creation Failed (MFB format))[Sun 05/17/2026 11:45:00] - End of Genesis manufacturing log.[Sun 05/17/2026 11:45:00] - Exiting...[Sun 05/17/2026 11:45:00] - Overall Result for Device: /dev/sg2 ****** FAIL ******[root@localhost SF_Genesis-v1.7]#
发表于 2026-5-17 14:40:13 | 显示全部楼层
发表于 2026-5-17 16:50:10 | 显示全部楼层
 楼主| 发表于 2026-5-17 23:11:40 来自手机浏览器 | 显示全部楼层
发表于 2026-5-18 00:05:59 | 显示全部楼层
发表于 2026-5-18 10:05:39 | 显示全部楼层
发表于 2026-5-18 17:13:49 | 显示全部楼层
发表于 2026-5-31 15:06:07 | 显示全部楼层
GMT+8, 2026-10-24 01:28 , Processed in 0.592801 second(s), 10 queries , Gzip On, Redis On.
