查看: 2146|回复: 4
[SandForce] 大佬们,帮看一下SF-2281开卡格式化失败
发表于 2023-3-22 16:30:59 | 显示全部楼层 |阅读模式
[Wed 03/22/2023 16:17:51] - Instructing the operating system to purge any existing cached data for device: '17:0:0:0'
[Wed 03/22/2023 16:17:56] - Issuing a discovery command for device: '17:0:0:0'
[Wed 03/22/2023 16:18:02] - Discovery command completed...
[Wed 03/22/2023 16:18:02] - Waiting 5 seconds for the system to settle...
[Wed 03/22/2023 16:18:07] - Device designation string '17:0:0:0' is mapped to node '/dev/sg2'
[Wed 03/22/2023 16:18:07] - Proceeding to process SSD device with the following parameters:
              DeviceName = /dev/sg2
    MFP Package Filename = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
      Configuration File = /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/29726.12345.driveconfig
              Serial No. = 12345
         World Wide Name = www_123
[Wed 03/22/2023 16:19:14] - FATAL_ERROR: Could not get the IDENTIFY data from the drive... (0x12000005:SF_SG_HOST_ABORT_ERROR)
[Wed 03/22/2023 16:19:14] - End of Genesis manufacturing log.
[Wed 03/22/2023 16:19:14] - Exiting...
[Wed 03/22/2023 16:19:14] - Overall Result for Device: /dev/sg2 ****** FAIL ******
[root@localhost SF_Genesis-v1.7]# lsscsi
[1:0:0:0]    cd/dvd  NECVMWar VMware IDE CDR10 1.00  /dev/sr0
[2:0:0:0]    disk    VMware,  VMware Virtual S 1.0   /dev/sda
[18:0:0:0]   disk    BUFFALO  HD-PCU2          0108  /dev/sdb
[root@localhost SF_Genesis-v1.7]# ./SF_Genesis -PROCESS_SSD 18:0:0:0 '/root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp' '/root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/29726.12345.driveconfig' 12345 www_123 log=/log/
SandForce Genesis Utility v1.7.0.01020130612-fc14-32bit
SF_Core Library: v1.7.1.20130612-fc14-32bit
Copyright 2010-2012, LSI Corporation, All Rights Reserved Worldwide.
[Wed 03/22/2023 16:20:15] - SF_Genesis has been invoked with the following parameters:
                      argv[1]: -PROCESS_SSD
                      argv[2]: 18:0:0:0
                      argv[3]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
                      argv[4]: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/29726.12345.driveconfig
                      argv[5]: 12345
                      argv[6]: www_123
                      argv[7]: log=/log/
[Wed 03/22/2023 16:20:15] - Instructing the operating system to purge any existing cached data for device: '18:0:0:0'
[Wed 03/22/2023 16:20:20] - Issuing a discovery command for device: '18:0:0:0'
[Wed 03/22/2023 16:20:25] - Discovery command completed...
[Wed 03/22/2023 16:20:25] - Waiting 5 seconds for the system to settle...
[Wed 03/22/2023 16:20:30] - Device designation string '18:0:0:0' is mapped to node '/dev/sg2'
[Wed 03/22/2023 16:20:30] - Proceeding to process SSD device with the following parameters:
              Serial No. = 12345
[Wed 03/22/2023 16:20:31] - Successfully received the IDENTIFY data from the drive...
[Wed 03/22/2023 16:20:31] - Validating Manufacturing Firmware Package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Wed 03/22/2023 16:20:31] - Successfully opened the package: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/FW_PPRO_6_0_A_Release.1134440.release.12345.mfp
[Wed 03/22/2023 16:20:31] - file  /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/29726.12345.driveconfig Loaded successfully
[Wed 03/22/2023 16:20:39] - B01 Power Management configuration request detected
[Wed 03/22/2023 16:20:39] - B01 Power Management conforms to hardware version 0x0
[Wed 03/22/2023 16:20:39] - Successfully extracted *.DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/29726.12345.driveconfig
[Wed 03/22/2023 16:20:39] - Extracted Config_ID: 1 (29726) in DriveConfig file: /root/Desktop/sf2281/MFP/FW_PPRO_6_0_A_Release.1134440.release--12345/Configuration_Files/29726.12345.driveconfig
[Wed 03/22/2023 16:20:39] - Extracted SerialOutputControl: 0
[Wed 03/22/2023 16:20:39] - Searching for flashware image for configuration 29726
[Wed 03/22/2023 16:20:39] - Manifest found for configuration 29726
[Wed 03/22/2023 16:20:39] - Flashware image extracted: 29726_fw_cl_mlc_Hynix_RDD_64Gb_H27QDG8UDE5R_2Q_4C_1D_S_PP_R03148_s512.vic
[Wed 03/22/2023 16:20:39] - Searching for manufacturing image for configuration 29726
[Wed 03/22/2023 16:20:39] - Manufacturing image extracted: 29726_mf_mlc_Hynix_RDD_64Gb_H27QDG8UDE5R_2Q_4C_1D_S_PP_R03148_s512.vic
[Wed 03/22/2023 16:20:39] - Proceeding in ROM mode, download feature 3...
[Wed 03/22/2023 16:20:40] - Successfully downloaded MFB to the drive...
[Wed 03/22/2023 16:20:40] - Waiting (5 sec) for the drive to settle...
[Wed 03/22/2023 16:20:45] - Successfully received the IDENTIFY data from the drive...
[Wed 03/22/2023 16:20:45] - Firmware revision reported to be: '60AABBM0'.  This indicates MFB download was successful.
[Wed 03/22/2023 16:20:45] - Successfully enabled SMART capabilities...
[Wed 03/22/2023 16:20:47] - Successfully issued a diagnostic unlock...
[Wed 03/22/2023 16:20:48] - Performing the flash test of block 0 (0x0000)...
[Wed 03/22/2023 16:20:51] - Flash Test Results:
Flash Test Parameters:
               Block Count: 0
                Page Count: 1
                 Bus Count: 2
        Chip Enabled Count: 4
                 Die Count: 1
                Lane Count: 4
               Plane Count: 2
Results Notes:
   N1 - At least one page tested and passed with no bit errors.
   N2 - No test data available.  Test may have aborted, or failed during the testing.
   N3 - At least one page tested and had errors less than or equal to half the range of ECC correction power.
   N4 - At least  one erased page tested had bit error rate greater than half the correction power.
   N5 - Walking zeros test failed.
   N6 - Walking ones test failed.
   N7 - Block contained factory bad block markings and testing was skipped.
   N8 - At least one page tested and had bit error rate greater than the correction power on plane 0.
   N9 - Block in plane 0 was marked as a factory bad block.
  N10 - At least one page tested and had bit error rate greater than the correction power on plane 1.
  N11 - Block in plane 1 was marked as a factory bad block.
| Bus  | CE   | Die  | Lane | Value  | Result Notes                               | Overall |
| 0    | 0    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 0    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 0    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 0    | 1    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 1    | 0    | 2    | 0x0042 | N3,N6                                      | WARNING |
| 0    | 1    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 2    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 2    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 2    | 0    | 2    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 2    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 3    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 3    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 0    | 3    | 0    | 2    | 0x0022 | N3,N5                                      | WARNING |
| 0    | 3    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 0    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 0    | 0    | 3    | 0x0002 | N3                                         | WARNING |
| 1    | 1    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 1    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 1    | 0    | 2    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 1    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 2    | 0    | 0    | 0x0002 | N3                                         | WARNING |
| 1    | 2    | 0    | 1    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 2    | 0    | 2    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 2    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 3    | 0    | 0    | 0x0022 | N3,N5                                      | WARNING |
| 1    | 3    | 0    | 1    | 0x0002 | N3                                         | WARNING |
| 1    | 3    | 0    | 2    | 0x0002 | N3                                         | WARNING |
| 1    | 3    | 0    | 3    | 0x0022 | N3,N5                                      | WARNING |
  Total Number of test results: 32
            Number of failures: 0
         Number of Passed with warnings: 32
      No. Passed without warnings: 0
[Wed 03/22/2023 16:20:51] - Performing the FORMAT Command with the following parameters:
         MemoryWearCycleCapability = 0
              CurrentPE_CycleCount = 0
                     LifeInSeconds = 0
                   LogicalCapacity = 500118192
                        SectorSize = 512
             SectorAlignmentOffset = 0
                  ExpectedMemoryID = 57005 (0xDEAD)
                   ExpectedNumDies = 0
               SerialOutputControl = 0
                           Time[8] = 0x0000000000000000
            MiscFlag_Erase_R_Block = 0
     MiscFlag_PanicHandlingEnabled = 0
        MiscFlag_PanicOnSATA_Error = 0
  MiscFlag_WriteThrottlingTestMode = 0
      MiscFlag_DisableUserBandECCX = 1
                        L_PageSize = 0
                        E_PageSize = 0
              ErrorCorrectionPower = 0
      ConfigDeviceReadDisturbCount = 0
   ConfigDeviceReadDisturbCountLow = 0
                  ExtraOptions_0_1 = 0
[Wed 03/22/2023 16:21:36] - FATAL_ERROR: Could not perform the FORMAT() operation on the drive... (0x12000005:SF_SG_HOST_ABORT_ERROR)
[Wed 03/22/2023 16:21:36] - End of Genesis manufacturing log.
[Wed 03/22/2023 16:21:36] - Exiting...
[Wed 03/22/2023 16:21:36] - Overall Result for Device: /dev/sg2 ****** FAIL ******
 楼主| 发表于 2023-3-22 16:32:05 | 显示全部楼层
发表于 2023-3-22 17:51:45 | 显示全部楼层
发表于 2023-3-23 00:12:19 来自手机浏览器 | 显示全部楼层
 楼主| 发表于 2023-3-23 09:28:44 | 显示全部楼层
GMT+8, 2026-9-8 11:18 , Processed in 0.156000 second(s), 9 queries , Gzip On, Redis On.
