查看: 1806|回复: 4
[软件] 轻量级虚拟机 VirtualBox v7.0.8-156879 官方版
发表于 2023-4-20 12:22:15 | 显示全部楼层 |阅读模式
Oracle VM VirtualBox – 免费开源轻量级虚拟机软件。该软件由德国InnoTek公司开发(后被SUN收购,之后SUN被Oracle公司收购),VirtualBox虚拟电脑×软件主要优势是完全免费,而且性能稳定,它可以在Linux和Windows平台中运行,可以在其主机上安装Windows, MacOS, Linux, BSD等类型的客户机操作系统。
软件截图
更新日志
VirtualBox 7.0.8 (released April 18 2023)
This is a maintenance release. The following items were fixed and/or added:
  • VMM: Fixed EFLAGS.TF handling for CPUID instructions when Hyper-V is used
  • VMM: Fixed MONITOR/MWAIT crash with Solaris guests when Hyper-V is used on Windows 11
  • VMM: Introduced general improvements in nested visualization area
  • VMM: Fixed triple fault related guru meditations for UEFI guests starting with macOS Ventura 13.3
  • GUI: Brought back Restore current snapshot checkbox of Close VM dialog
  • GUI: Fixes and validation for VM settings USB filters editor, filter port value is now properly saved/restored
  • GUI: Fixes for VM name and OS type embedded editors of Details pane
  • GUI: Cloud related wizards should now propose enabled profiles before disabled
  • Oracle VM VirtualBox Extension Pack: Fixed shipping the cryptographic support module for full VM encryption
  • E1000: Fixed possible guru meditation when changing network attachments (bug #21488)
  • virtio-net: Follow up fixes for FreeBSD 12.3 and pfSense 2.6.0
  • 3D: Fixed various graphics issues with Windows 7 guests
  • Main/UefiVariableStore: Added API to add signatures to the MOK list (Machine Owner Key)
  • VBoxManage: Introduced modifynvram enrollmok sub-command to enroll Machine Owner Key into NVRAM, so Linux guest kernel can pick it up in order to verify signature of modules signed with this key
  • Guest Control/Main: Fixed deleting files via built-in toolbox
  • Linux host: Added possibility to bypass kernel modules signature verification once VBOX_BYPASS_MODULES_SIGNATURE_CHECK="1" is specified in /etc/vbox/vbox.cfg, useful in case if Linux distribution does not provide necessary tools to verify kernel module signature
  • Linux Guest Additions and host Installer: Improved detection if system is running systemd as the init process
  • Linux Guest Additions and host drivers: Introduce initial support for kernel 6.3
  • Linux Guest Additions: Added possibility to bypass kernel modules signature verification once VBOX_BYPASS_MODULES_SIGNATURE_CHECK="1" is specified in /etc/virtualbox-guest-additions.conf, useful in case if Linux distribution does not provide necessary tools to verify kernel module signature
  • Linux Guest Additions: Added experimental support for kernel modules and user services reloading in the end of installation process, thus guest system reboot after Guest Additions (7.0.8 and newer) upgrade is no longer required in general case
  • Linux Guest Additions: Fixed vboxvideo build issue with RHEL 8.7, 9.1 and 9.2 kernels
下载地址
官方下载        本地下载        飞机盘        字节云
发表于 2023-4-21 08:01:37 | 显示全部楼层
发表于 2023-4-21 08:16:42 | 显示全部楼层
发表于 2023-4-21 10:53:23 | 显示全部楼层
发表于 2023-4-21 11:46:46 | 显示全部楼层
发表于 2023-4-21 23:27:10 | 显示全部楼层
GMT+8, 2026-10-29 03:29 , Processed in 0.124801 second(s), 11 queries , Gzip On, Redis On.
